ECU question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2009, 11:26 AM   #1 (permalink)
View nevanerviss's Photo Gallery
ECU question
Will an ECU from a 95 Camry work on a 96 if all the other things are the same, i.e. auto, cruise, motor, etc.?
I'm at my wits end with my car; I can't figure out why the fuel pump is not getting power, even though I've changed ALL the relays and fuses associated with the fuel system... I'm beginning to think the ECU is blown, but why would it be??
The only ECU that I can get free is one from a 95 Camry...
Please help...
nevanerviss is offline   Reply With Quote
Old 11-10-2009, 12:41 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
4cyl - ecu won't work
6cyl - ecu might work, but idk
As for the fuel pump, all I can think of is start tracing the power wires back while measuring voltage until you find 12v.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-10-2009, 01:59 PM   #3 (permalink)
Gameroom cash: $303255
When I have a question like this I go to one of the online vendor's sites and check the part number for each year. If the part number is the same you have your answer.
Mike
Old 11-10-2009, 02:07 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Originally Posted by nevanerviss View Post
...The only ECU that I can get free is one from a 95 Camry...
Please help...
Get it, plug it in, and see if that works. You said it's free, so what have you got to lose?
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 11-10-2009, 04:24 PM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
odbII to ODBI
free why not.
^ and leaving it that way!
Old 11-10-2009, 05:12 PM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Oops, misread and incorrectly assumed this was a 1995.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-10-2009, 05:20 PM   #7 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Originally Posted by Stillrunning View Post
Did you do the check with terminals jumped on data link connector: +B and FP - ignition on/engine off?
95 FSM says if pump not running check:
1. Fusible link
2. Fuses; AM2 30amp, EFI 15amp, IGN 7.5amp
3. EFI main relay
4. Fuel pump
5. Wiring connections
It does not say check ECU.
1996 changed quite a bit. Jumpering B+ and FP does nothing on that year 5S-FE. I've emailed nevanerviss the fuel pump troubleshooting section from the 1996 FSM for the 5S-FE. I assume I'd get spanked by the mods if I posted it here directly...I've already been spanked for posting direct links to the FSM info on camrystuff.
Old 11-10-2009, 06:51 PM   #8 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
No, 96 was OBD2.
Also Fed and Cali are different. The part #'s should match.
5 Lug Corolla WHAT?
