I've read up on all the how-to's for CV shaft removal and installation after finding a boot crack and leak in my left-side inner CV boot. I wasn't going to bother with fixing the boot and instead was going to replace the whole drive shaft. I was working up the courage to do the job myself and before ordering the new shaft assembly for the left side, I was wondering If I should replace the right side as well?
It looks like the new assemblies come with new axle nuts, but not sure about reusing the old snap rings. Am I missing anything for this job, parts-wise? Also, what do-it-yourselfer has done this job (strictly replacement of whole assembly) and how much time is necessary?
Comments/Adivce is much appreciated!
1995 Emerald Green Metallic Camry Coupe DX, manual with 180K miles
"And having been perfected, He became to all those who obey Him the source of eternal salvation,"
Hebrews 5:9
If you inspect the other side and the boot is fine you might want to wait. You should also check engine mounts because if the mounts are bad the boots can tear more easily.
The new/rebuilt axle should come with one axle nut and a circlip for the snap-in type? No? I'd just get a new circlip from the dealer. It's a $2-3 or so.
Work carefully so you don't damage the oil seal on the differential. Of course, unless you want to change that as well while it's apart.
Get a torque wrench suitable for the range you need. Tighten the axle nut while the wheels are off the ground. Don't touch the sway bar unless both wheels are off the ground or the sway bar will be loaded with tension! Not too healthy.
If there is any protective grease on the axle nut threads (for protection during shipping) clean it off with brake cleaner. You need a clean thread so you don't over torque the axle nut.
you will need the following
floor jack
set of jackstands
1/2 long ratchet or impact
21mm socket for OEM lugnuts or 19mm for most aftermarket
17mm socket for balljoint fastners
18" or longer pry bar
30mm axle nut socket
set of dykes or linesman pliers for removing the cotter pin
torque the cv axle nut to 217ft lbs
the balljoint mounting bolts get torqued to 94 ft lbs and it says to torque the wheel to 76 ft lbs i had mine tore down in about 20 minutes but i had just put it together then during my test drive my cv axle snapped but its all getting fixed tomorrow
Whaddya mean it snapped? Where did it snap and why?
floor jack
set of jackstands
Hebrews 5:9
it snapped inside the diff from old age i bought the car for $500 with a blown diff and replaced the whole tranny and reused the old axles prolly didnt get one pushed into the tranny all the way but it was no big deal its fixed now just figured id give ya those torque specs striaght out of the gen 3 camry toyota service manual
Thanks, well I got my new left and right Cardone Select driveaxles from Rock auto for $50 and $60 respectively...what a deal, why would anyone considering working on a boot when the whole replacement part is so cheap?...anyways...
I will purchase some new tranny fluid, cotter pins, and high temp grease to coat the splines. New driveaxles came with ABS rings, one circlip on differential side of left side axle, snap ring on intermediate shaft side of right axle, and new axle nuts. My differential oil seal was just replaced at the dealership a month ago so I am not planning on replacing that. Looks like I am not going to need anything else in the way of hardware....so wish me luck!
Hebrews 5:9
stbradle
Have you completed replacing both the half shaft axle assemblies? Can I humbly request you to post DIY photos/video to let me know
-How much time it took for you to do both sides? ~4 hours?
-What tools are needed?
-What lubricants are needed?
-What seals/pins/clamps etc are needed?
-WHat are the part numbers that you ordered for both Front right and left half shafts?
-How much did you pay in all to RockAuto including shipping and taxes? (~$110?)
Mine is a 95 Camry L4 sedan and and my front driverside outer CV joint clicks. I want to replace both axles to avoid all the hassle of take out the joint-clean innner-assemble outer...
__________________ 1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
stbradle
Hi peshwa,
Part Number Part Type Price EA Core EA Quantity Total
1995 TOYOTA CAMRY DX 2.2L 2164cc L4 MFI (S) [5SFE]
CARDONE SELECT 665044 (66-5044) CV Half Shaft Assembly $ 65.99 $ 0.00 1 $ 65.99
CARDONE SELECT 665038 (66-5038) CV Half Shaft Assembly $ 50.79 $ 0.00 1 $ 50.79
Discount $ -5.84
Shipping Ground (FedEx or UPS) $ 11.64
Order Total $ 122.58
I didn't get to replacing them yet. Total price was about $120.00. I am planning on working on the axles in a few weeks since I am finishing up school and don't have the time. I will take pictures and post a simple diy afterwards.
Hebrews 5:9
Excellent!Thanks a ton!
We have same engine specs :-) Looks like both of us will be doing our axles around the same time then!
Can some TNer enlighten us about rest of my questions?
