EGR Valve Sensor - Resistance Values - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2009, 09:24 PM   #1 (permalink)
aznriptide859's Avatar
View aznriptide859's Photo Gallery
Hey this is a bit of an urgent request:
I went to AutoZone the other day to check my engine light codes, and the guy pulled up a P0402, which means the EGR valve/EGR sensor has gone bad. I've checked the sensor - the end was pretty gunked up, and so far I've cleaned it. However I'm getting very big resistance readings - almost 200kOhms.
My question is, was that gunk causing my engine light to turn on, or has the entire sensor gone bad? If it did go bad, shouldn't I have no resistance reading at all?
My engine is open ATM, and I need it for work tomorrow, so if someone could help me ASAP, I'd be deeply thankful. Thanks!
aznriptide859 is offline   Reply With Quote
Old 11-10-2009, 09:38 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
well the senor wuld be bad if it give a reading out of spec, i think 200k is right for cold i know hot (to where it closes) is about 47k. i just bypassed mine with a resistor and trashed the whole egr
^ and leaving it that way!
Old 11-10-2009, 09:51 PM   #3 (permalink)
Did a quick test - heated up the end of the sensor, resistance dropped. That means the sensor is working.
Does that mean the gunk did have something to do with it?
Old 11-11-2009, 04:53 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
i'll go with yes, also try and clean out the rest of the egr, and vacuum modulator
Old 11-12-2009, 09:21 AM   #5 (permalink)
Grr, light came back on. Though sensor works, which really confuses me. Could it be the entire valve that has gone bad?
Also:
How do you use a vacuum to test if the EGR valve works or not?
How can you clean the EGR system tubes? Can you just spray carb/choke cleaner and let it sit?
