1995 Camry LE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2009, 09:52 AM   #1 (permalink)
The TN Community Sucks
SnoFox4's Avatar
View SnoFox4's Photo Gallery
3rd Generation 1995 Camry LE V6
I just... acquired a '95 V6 for free.
The car was my sister's but my parents bought her a 2009 Acura TL last year, so she gave the car to me.
The car's been sitting for about a year, but I remember driving it before she put it away. The transmission and everything were buttery smooth..
The transmission (4-spd auto) isn't shifting smoothly now, the battery on the car had been dead for some time so I'm sure the PCM was reset but it's been about 50-75 miles and it's still not shifting great, the car jerks forward in every gear. Should I try resetting it again?
Also, when I filled up for the first time and I unscrewed the fuel cap it hissed (pressure release) until I got the cap off, then the car began to idle roughly after that (filled with 93).
The car is pretty quick though! (besides the weird shifting) My other car is a '02 Impala and I think that the Camry is wayyyyyyyyyyy faster!
SnoFox4 is offline   Reply With Quote
Old 11-11-2009, 10:19 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
First, if it were my car, I'd have the transmission serviced, and I'd run a can of seafoam in a full tank of gas, just because it sat for a year. That may just fix it.
How many miles on the Car?
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 11-11-2009, 10:37 AM   #3 (permalink)
SnoFox4's Avatar
The car has 190,3XX miles, the transmission was flushed at 150K miles according to the records, so I don't think it needs a service unless sitting causes some sort of reaction with the fluid.
I'm afraid of Seafoam because of what it can do to older engines.. I ran 1/3 of a can of Seafoam in my Impala's oil and it leaks now.
Also, I've read that it isn't that great for the catalytic converter.
Thanks for the reply!
Old 11-11-2009, 05:58 PM   #4 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
do you think it's time to change the AT filter and fluid again? Cuz it's a 30,000 mile maintenance interval on our cars i believe
RU2CHKN is offline   Reply With Quote
Old 11-11-2009, 05:59 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
seafoam cleans everything...so any old crapy seals or gaskets that have been broken down by oil will fall victim to its cleansing powers. but that just means its time to replace gaskets. id rather have a clean engine then a dirty engine that doesnt leak.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-11-2009, 07:08 PM   #6 (permalink)
SnoFox4's Avatar
Oh, does the trans not need to be flushed like on my Impala?
Heh, if it doesn't then I can just change it in my garage.
30K miles though... ouch... it's overdue.
I should get some pics up too, just finished spot cleaning the engine bay and the engine purrs like new, just a little rough.
Old 11-11-2009, 07:14 PM   #7 (permalink)
Super Moderator
eyeball96's Avatar
You keep comparing your Camry to your Impala...totally different cars!
I've been using Seafoam in my Vehicles for years, and I've never had a problem with it. Good stuff, it really is!
98 Honda CRV
08 GMC Crew
Old 11-11-2009, 07:24 PM   #8 (permalink)
SnoFox4's Avatar
Sorry, lol.
My Impala is my first car, so I'm used to only caring for it. I don't have to get transmission flushes until every 60K+ miles with it too.
As for the Seafoam, I'll do it if I disconnect the cat. Lol, it just worries me especially since it's never been done on that engine, and the crap that comes out the back could easily clog/ superheat some things.
I think I'm going to try resetting the PCM because my Sister likes to floor it a lot and that's probably not a good thing to do when the PCM is relearning.
Old 11-11-2009, 07:34 PM   #9 (permalink)
Gameroom cash: $160210
View FLIP K1DD's Photo Gallery
seafoams bad for the cat?? inform me more plz i never knew that
FLIP K1DD is offline   Reply With Quote
Old 11-11-2009, 07:58 PM   #10 (permalink)
SnoFox4's Avatar
Well yeah, Cat's are designed to take CO and convert it to CO2 using super high temperatures. When you run a cleaner through an engine it knocks a BUNCH of stuff loose that is then burned causing higher than normal CO output and thus super heating the catalytic converter.
It says right on the bottle not to use it in high mileage applications due to the ill effects it's had on engine and exhaust components from the sheer amount of gunk that is outputted.
Old 11-12-2009, 04:18 AM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
hmm...never herd of this happening on any camrys...maby another impalla thing.
it should be fine on the cat. if somthing happens to it...then the cat was goin bad anyways.
as far as trannys...i HATE what GM did with their "non-service requiered" trannys. my girls cavalier HAS to be taken to a dealership and only a dealership just to change the fluid and it has to be changed JUST as often as my camry to run its best...which i can do myself.
R.I.P.
Car Domain:
Old 11-12-2009, 06:35 PM   #12 (permalink)
SnoFox4's Avatar
I had the fluid and filter replaced today, but the car still doesn't shift as buttery as it did before.. any clues?
Old 11-13-2009, 01:08 PM   #13 (permalink)
Super Moderator
eyeball96's Avatar
I found this on "How stuff works"
Automatic transmission (1992-96): The "A-40 series" automatic transmission may shift harshly because rubber check balls shrink, blow through a plate, and become dislodged.
Maybe your balls shrunk, from the car sitting so long??
98 Honda CRV
08 GMC Crew
Old 11-13-2009, 04:10 PM   #14 (permalink)
SnoFox4's Avatar
Lol, I hope not.
It's not very rough but the shifts weren't noticeable before the car sat... so it's possible.
As long as it's not a big problem and there's no excess wear on the car as a result I wont worry about it.
Old 11-13-2009, 05:06 PM   #15 (permalink)
Super Moderator
eyeball96's Avatar
I'll tell ya what....I'm going to began driving mine more often, so my Balls don't shrink!!
98 Honda CRV
08 GMC Crew
