*LED Work* A/C and Rear Defrost Button Access/size... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2009, 10:24 PM   #1 (permalink)
Hi.
View mystickid's Photo Gallery
4th Generation *LED Work* A/C and Rear Defrost Button Access/size...
Guys,
So Far I've changed my all my Guage Cluster Incandescent Bulbs and HVAC controls to White a LEDS. They Look Great!!!
I did search and used El Tano's very helpful picture DIY thread.
But Do you guys know what size/type Bulb is on the A/C Button, Rear Defrost Button and Cigarette Lighter?
Also any pics on how to open the A/C Button, Rear Defrost Buttons? I got in there but don't know how to open those to buttons up without breaking em'.
Pics on how to get to those buttons and sizes please?
mystickid is offline   Reply With Quote
Old 11-13-2009, 12:10 PM   #2 (permalink)
Momentum Car Crew Camry
View H.Rivera's Photo Gallery
just ah sugestion.. personally me.. i got to the pic ah part and practice anything big out there and so i can do it right when it comes to my car.. just ah thought.
H.Rivera is offline   Reply With Quote
Old 11-13-2009, 04:43 PM   #3 (permalink)
View djb2's Photo Gallery
The cigarette lighter lamp is a special part. The bulb is soldered directly to the connector.
It's a good candidate for a reliability upgrade. It took ages to find one in the boneyard that wasn't already burnt out. But there isn't much room for both an LED and resistor.
djb2 is offline   Reply With Quote
Old 11-13-2009, 08:59 PM   #4 (permalink)
Hi.
I tried my best to get good quality pics but for the life of me I couldn't take them correctly.
All the LEDS are vivid and bright in the Lights
The Cluster Insanely bright LEDS such that I have to use the dimmer sometimes at night.
The cluster has two hot spots but otherwise has great color temperature and even spread.
This is How my white LEDs in the Guages, HVAC, Shifter, License Plate , trunk, Map and Dome Lights look so far.
This is the White LED in the Trunk.
License plate light
This the bulb for the Cigarette Lighter, I'm trying to figure out How to get an LED bulb to replace it.
Any help on how to Access the A/C and rear deforster button. Pics would greatly help.
Old 11-17-2009, 08:10 PM   #5 (permalink)
Hi.
*Bump*
C'mon guys, Anyone change their AC button or rear defrost? It would be great if you can share how to access them....
Old 11-17-2009, 08:18 PM   #6 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
what bulbs and how many did you use for the guage clusters? good job on the work btw!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 11-18-2009, 04:34 PM   #7 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I've replaced both those bulbs on the A/C and rear defroster.
I honestly don't remember how but I did.
It wasn't hard.
I remember I pulled the whole HVAC unit out, and once I got the buttons out, there was a circle with an x indentation in it. Unscrew that and there's your bulb!
Chris Crash is offline   Reply With Quote
Old 11-18-2009, 09:52 PM   #8 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
It wasn't hard.
Do you remember what size is the bulbs for the A/C and rear defroster? 3mm, 4mm, or 5mm?
ty**20 is offline   Reply With Quote
Old 11-18-2009, 10:47 PM   #9 (permalink)
I have no idea what sizes you're talking about.
But I THINK maaaaaaaaaaybe they were the same size bulb as the gauge lights.
I'll check this weekend for you.
Old 11-18-2009, 11:44 PM   #10 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Originally Posted by mystickid View Post
*Bump*
I've removed the A/C control unit before. I've also removed the three switches. A/C, Recirculation, and Defrost. The bulbs in there are very small. They are about the size of that cigarette lighter bulb... if not smaller?
I'm not sure if I will have time tomorrow, but if you still haven't figured it out, maybe I can take it out and snap a few pictures. The only hard part about the whole thing is the cable that goes from the temperature control knob to someplace inside the dashboard. That thing was I pain, last I remember.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 11-19-2009, 11:41 AM   #11 (permalink)
Alright cool..cuz i know the light in the gauge are #74 and #194..I've seen other who took the bulb out of the a/c and defroster and they look smaller then the bulb in the gauge and i don't know what size is it.
Old 11-19-2009, 02:13 PM   #12 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
For kicks I rigged up a #74 LED bulb into that cigarette lighter bulb socket just to see what it looked like. I basically had to wrap the back end of the lighter socket up with electrical tape to hold it all together. The light has to bend all the way around to illuminate that ring. With a LED it does a good job of lighting up the bottom half. Thats about it. If you have a good working bulb I wouldn't worry about it. I tried some foil to reflect some more light to point it up towards the top of the ring. It looks ok. But not great.
#2! is offline   Reply With Quote
Old 11-21-2009, 03:31 AM   #13 (permalink)
These are a couple bulbs from the assembly.
They are not original, but they say JKL EWG203, if that gives you any information about their size.
The A/C and Defrost switches both use the same size bulb. The bottom of the base has the number 4 on it. The defrost switch also uses another smaller size bulb, but it seems to be missing from my switch. I probably couldn't find it in the auto stores when I was replacing them a couple years back.
The recirculation switch is a bit different. It has a circuit board, with two LED's soldered onto it.
Hope this helps!
Old 11-21-2009, 05:16 PM   #14 (permalink)
Hope this helps!
Thanks, Haux. I took out my A/C console today. Those lights side are tiny as hell. I wonder why there are two bulbs for the defroster button? My bigger bulb had a yellow cover and smaller with green. I hope the 4 means 4mm, cuz i wanna get the right size bulb on the first try. Are you going to change the bulb to another color? Thanks, for the pics.
Old 11-21-2009, 09:13 PM   #15 (permalink)
View Jeff T's Photo Gallery
Thanks for the pics of the end product, but does anyone have pics on how to take the dash apart to get to A/C and RWD buttons?
Thanks!!
Jeff T is offline   Reply With Quote
