oil leak..2000 solara 4cyl. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2009, 07:58 AM   #1 (permalink)
View jim2000solara's Photo Gallery
2000 4cyl. solara...changed VC gasket...still have leak..looks like from behind coil pack...is there a(n) plug or seal, or anything else, in that area that may be the culprit?..any info would be appreciated...thanks
jim2000solara is offline   Reply With Quote
Old 11-15-2009, 04:39 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
There's a plug where the distributor used to be on the older 5S-FE motors -- sometime it'll leak oil. Just below the valve cover on the driver's side of the motor. P/N 90339-36001 .
Old 11-15-2009, 05:13 PM   #3 (permalink)
leak
thanks hill...that's probably it...do i take the coil pack off and the bracket to get to it?..
Old 11-16-2009, 05:23 PM   #4 (permalink)
Thumbs up leak
Just for info...I just have to remove VC to replace...$5.00 at dealer.
Old 11-17-2009, 05:04 AM   #5 (permalink)
View sboppana's Photo Gallery
4th Generation
just to know.... what kind of engine oil are you using!! because my 2000 camry didn't had any engine oil leaks until I switched to pennzoil full synthetic engine oil... I had it changed at 143k and after driving it for 1000 miles the engine sounds horrible, pickup was dead and started leaking.. but couldn't figure it out from where it's leaking... either gasket or something else.... DON'T GO FOR FULL SYNTHETIC ENGINE OIL ON HIGH MILEAGE VEHICLES.... it happened the same on my friend's 99 camry 4 cylinder.... 112k....
sboppana is offline   Reply With Quote
Old 11-17-2009, 09:19 AM   #6 (permalink)
hill8570's Avatar
Glad it was so easy to get to...I was drawing a blank on the access. Did it stop the leak?
Old 11-17-2009, 09:29 AM   #7 (permalink)
hill8570's Avatar
That's painting with a pretty broad brush, but yeah, if you've got a rig with marginal seals, the synth is going to make it past the seals easier than dino. Personally, I just run synth (since it's way less likely to sludge), and fix any leaking seals. The 5S-FE is the oil leaker from hell, anyhow...IMHO, replacing the camshaft, crankshaft, and oil pump seals (along with the water pump) should be part of the timing belt service on the 5S-FE. You could also go with high-mileage synth -- it'll swell the seals up enough to fix any little leaks.
Weird that your rig is having driveability problems from the synth, 'tho -- that's real rare. Are the plugs oil fouled? Not sure what else the oil could get to that would cause that sort of problem.
