moisture can collect in the cap and cause a rough idle. keep us posted on that issue after you get the cap seal installed. did you install new plugs and wires? if so, were the plugs correct and were they gapped to factory spec? have you checked the timing since the head job? finally, did you replace the fuel filter when you did the head job?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
