1995 Cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 06:42 AM   #1 (permalink)
View Folken's Photo Gallery
Canada 1995 Cold start
You know how the engine rpm goes >1000 when you first start up and then you have to kick it lower or it goes lower?
Well this morning I noticed mine goes right to 800 and falls right off and engine dies.
It may have been doing this for a while but didin't die cause it was still warm in the morings; but I noticed this morning cause it was cold out and it dies right away unless I keep my foot on the acelerator.
Once warmed up it was Ok and I went to work.
Any ideas why the rpm drops immediately now and how to fix?
...............Thanks in advance Folken..............
Folken is offline   Reply With Quote
Old 11-16-2009, 06:59 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
could be a few things. my initial thought points to a faulty coolant temperature sensor. this will send a signal to the ecu letting it know that the engins temps are low and to increase the idle to warm the engine up.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-16-2009, 07:35 AM   #3 (permalink)
you mention some other ideas. Can you share them please?........
Old 11-16-2009, 09:32 AM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
I'll second mazdaverx7 -- 90%+ it's the coolant temp sensor. Follow the top coolant hose back from the radiator to the engine -- the coolant sensor is the one with two wires going into it, and usually a green connector. Are you getting a Check Engine Light? A hard-fail (open or short) on this sensor will cause a CEL, a DTC 22, and cause the computer to default to the "warmed up" condition (which don't work for crap on a cold engine). Lots of times, 'tho, the sensor soft-fails (just gives readings that are "off" enough to cause problems). The 5S-FE portion of the Gen3 manual over on www.camrystuff.com has a nice write-up on testing the coolant sensor (look for the portion of the 5S-FE section that discusses troubleshooting DTC 22).
Old 11-16-2009, 06:00 PM   #5 (permalink)
Gameroom cash: $303255
My guess would be a dirty/carboned up idle air control valve. That was my problem with my 5SFE. Cleaning the idle air control valve solved my issue and now the car revs to around 1300-1500 on initial cold start and then immediately drops to 1200. From there it will drop slowly to 800 as it warms up.
Mike
Old 11-16-2009, 07:39 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The Idle Air Control valve is notorious for that. However, I've heard the Coolant Temperature Sensor can contribute to that. An ohm test on the sensor is quick and easy. So check both.
Old 11-16-2009, 07:47 PM   #7 (permalink)
Canyon Killer
View ekopel's Photo Gallery
I've actually experience both. Just do the check for both like the boys say.
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 11-16-2009, 07:47 PM   #8 (permalink)
Canyon Killer
if it is your coolant temp sensor, I have another one.
Old 11-17-2009, 07:54 AM   #9 (permalink)
mazdaverx7's Avatar
i would definatly test both the coolant temp sensor and the idle air control valve per the fsm.
85 RX-7 GS 5spd
Old 11-17-2009, 09:59 AM   #10 (permalink)
I have the dealer telling me it needs a new IDC and they will not clean the throttle valve as they said it could make the probelm worse. They want $1,000+ for the job.
I said no thanks..........Folken
I will check the coolent temperature sensor and then clean the throttle myself next..........thanks
Old 11-17-2009, 10:11 AM   #11 (permalink)
hill8570's Avatar
Also, start asking your friends for recommendations for an honest, competent mechanic. Even if you fix this yourself, it's always good to have a go-to guy available when the problem is beyond your abilities. Your stealership doesn't sound like the sort of place I'd want to deal with.
Old 11-23-2009, 03:54 PM   #12 (permalink)
Canada Good news....BUT......?
Hey guys,
I have cleaned the throttle body myself using the suggestions.
lots of 'crap' in there.
It has made a 'step' change in that now the revs go to about 1100 and then die to about 800-900 when warm ( before it was only going to 900-900 even on a cold morning and then diying sometimes).
So it is better BUT... what should the revs be on a cold start?? I have a feeling it should still be better ie. higher maybe closer to 1500 but I have not seen any stats.............
thanks Folken
Old 11-23-2009, 05:41 PM   #13 (permalink)
Hey guys,
thanks Folken
From my earlier post:
"My guess would be a dirty/carboned up idle air control valve. That was my problem with my 5SFE. Cleaning the idle air control valve solved my issue and now the car revs to around 1300-1500 on initial cold start and then immediately drops to 1200. From there it will drop slowly to 800 as it warms up."
You may need to do a more thorough cleaning of your idle air control valve.
Mike
Old 11-24-2009, 06:45 PM   #14 (permalink)
Canada
Mike
Sorry I missed that...........I will get some more work on it on the weekend.........Thanks Folken
Old 12-01-2009, 06:26 AM   #15 (permalink)
Canada 1995 Cold Start
Ok I cleaned the throttle and IAC- by spraying, toothbrush etc.' as suggested in posts- but it seems to be about the same. ie. not a real good cold start.
I noticed something wierd though- when cold the upper hose is all crunched up- like it's under vacumn or something??
Does this mean I just need a new upper hose or does it point to some other problem?
Thanks Folken
