Replaced stock struts (125K miles) with KYB GR-2s yesterday... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 07:08 AM   #1 (permalink)
View hokie_sti's Photo Gallery
My friend owns a '99 Camry 2.2L. His car has 125K miles on it and was riding like a boat (i.e. bottoming out over small bumps, massive body roll when turning, and just general sloppy handling). I replaced the struts on my wife's corolla with GR-2s so I suggested that he order a set and we would install them.
We got the fronts done within 90 minutes. By the way, his car has 22mm knuckle/clevis bolts up front so I ended up buying an impact socket set just to get a 22mm socket.
The rears took FOREVER. It took about 30 minutes to figure out how to remove the rear seat. Then the rear endlink bolts stripped on both sides (sprayed PB blaster and let it sit for a while before doing the work... this still didn't help). It was getting late so we zip tied the rear sway bar out of the way and he'll pick up new endlinks this week.
The top hats were still in decent shape. 3 out of the 4 dust boots were in decent shape. The springs were still good. So all of the good parts were reused.
The ride/handling difference is incredible. Even as a passenger the car felt more stable and planted. The GR2s soak up the bumps really well, but still give you enough road feedback to let you know you're in control. Now this isn't really a performance upgrade from stock ... just a stock replacement.
I give the KYB GR2s a thumbs up for anyone wanting to replace their stock struts and reuse their other stock suspension components.
- 2008 Subaru Impreza STi (mine)
- 2002 Toyota Corolla CE (hers)
hokie_sti is offline   Reply With Quote
Old 11-16-2009, 07:15 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
thanks for the review! what did the parts total cost? i'm considering replacing my front struts (rears are new) and i hadn't looked into any replacements just yet. so, i was curious what this set of four cost you friend.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-16-2009, 07:22 AM   #3 (permalink)
He shopped around and was about to get them for around $65 per corner with free shipping. If you go a google search for "coupon code <insert parts website name here>", you can usually get 10-20% off the order and/or free shipping. They retail for about $110 each at Advance Auto Parts.
I forgot to add, he has a shop manual. So we grabbed the correct torque specs from that and all the nuts/bolts were torqued to spec.
Old 11-16-2009, 01:58 PM   #4 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
The GR-2's are actually considered performance struts, just the very bottom end of the ladder
I mated mine with performance springs as well and it's everything you said X2!
Good work, the back suspension IS a real bitch
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 11-16-2009, 02:57 PM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
good job on torquin' them to spec! - most aren't too diligent with that stuff.. plus i'd check on them again in a week, to make sure nothing broke loose or shook loose.. suspension stuff takes massive beating. hehehe!
i have GR2's and S-Techs on mine!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 11-16-2009, 03:43 PM   #6 (permalink)
Yeah, I'll go over the nuts/bolts again with the torque wrench when we install the rear endlinks next weekend.
Old 11-17-2009, 11:45 AM   #7 (permalink)
View Dick Tuck's Photo Gallery
I have GR 2s on my 99, after a week or to they break in and are not as stiff as when first mounted but still better than OEM. If you have an I4 and put stiffer shocks on you might consider a front strut bar.
Dick Tuck is offline   Reply With Quote
Old 11-17-2009, 12:08 PM   #8 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
What would be the benefit if having a strut bar?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 11-17-2009, 01:17 PM   #9 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
It's also called a strut tower bar and stiffens up the front of the car. I have the TRD strut bar and noticed a little more understeer but with more control during hard cornering.
I can also vouch for the KYB GR-2's, as I had them for almost 5 years with no problems.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 11-17-2009, 01:25 PM   #10 (permalink)
Think this JDM one would be worth getting?
http://cgi.ebay.com/ebaymotors/ws/eB...m=360206770225
Old 11-17-2009, 05:50 PM   #11 (permalink)
on full afterburner
Gameroom cash: $1339697
That's not JDM at all!
Old 11-17-2009, 06:15 PM   #12 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
I run GR2's, H&R sports springs, and a TRD RSB on the 96, and they perform fine. Handle great.
But having owned and driven another Coupe with Tokicos, the same spring, and RSB...I prefer the Tokicos myself!
The car just felt more glued to the road to me!..IMO
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 11-17-2009, 06:35 PM   #13 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
KYBs are awesome that's what im running with now along with my eibach pro-kits and TRD rear sway bar
RU2CHKN is offline   Reply With Quote
Old 11-17-2009, 09:51 PM   #14 (permalink)
Well shoot, thank you for pointing that out! If I can't find a TRD one, can somebody point me toward one of good quality?
Old 11-18-2009, 08:49 AM   #15 (permalink)
I've run Tokico Dspecs (adjustable) with STI springs and STI top hats on my previous car (2005 WRX). It was a fantastic combo. The adjustability of the Tokicos was really impressive. They handled track days and autocross really well.
You'll notice more of an improvement from larger sway bars.
