I think I blew my headgasket of my 1mz-fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2009, 03:15 PM   #1 (permalink)
96 es300 2mz-fe
Gameroom cash: $135325
View Brandoe91's Photo Gallery
Check this video out and tell me what you think..
Brandoe91 is offline   Reply With Quote
Old 11-18-2009, 07:33 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
its kinda hard to tell from that where exactly the smoke is commin from but its has signs of a blown HG. is there white smoke comming out of the exhaust? is your temp gauge reading higher then normal? any power loss?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-18-2009, 07:58 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Do you have coolant in your oil? Or oil in your coolant? Run a compression check. That will tell you alot.
I would also look for a coolant or oil leak. It may be dripping on something hot and causing the smoke.
How does it run? Power loss? Usually , if there's a blown HG it runs like crap or won't even start.
The Jedi Speeder at CarDomain
Old 11-18-2009, 08:10 PM   #4 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Can't tell you what I think coz you haven't given us stuff all information.
Video's useless. Could be anything mate.
whip_cracker is offline   Reply With Quote
Old 11-18-2009, 09:25 PM   #5 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah the video reminds me of a leaky valve cover on a old olds i worked on recently. If your coolant levels fine and no smoke out the exhaust your fine.
Its most likely a leaking valve cover gasket, which shouldent be to bad of a job.
carsrus is offline   Reply With Quote
Old 11-18-2009, 11:45 PM   #6 (permalink)
96 es300 2mz-fe
pics coming soonn
I have a coolant leak because I need a new water pump.a really small oil leak ...exhaust has no white smoke coming from it and there is no power lost..I will upload a few pics soon
Old 11-18-2009, 11:56 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Then what makes you think it's a blown HG ?
Old 11-19-2009, 12:23 AM   #8 (permalink)
View gottarollwithit's Photo Gallery
These guys are givin ya good advice.
Blown head gaskets usually have low compression - compression sometimes squirts out into the coolant reservoir. Oil in coolant, white exhaust from burnt coolant in the cylinders, coolant in your intake, leaking oil from the base of the head, running on only a few cylinders, etc.
Your motor sounds fine. That white smoke could be coming from anything! Burnt wires, burnt oil?? Find the source. Compression test will verify integrity of your cylinders - you're probably fine.
You haven't overheated the motor lately, have you???
gottarollwithit is offline   Reply With Quote
Old 11-19-2009, 01:08 AM   #9 (permalink)
96 es300 2mz-fe
I think it's blown because I was driving and it started to over heat .Then it got so hot the engine just stop running.. leaving me stranded on the highway
Old 11-19-2009, 01:09 AM   #10 (permalink)
96 es300 2mz-fe
If you look closely you can see a piece of rubber like material coming out ot the block...someone was telling me its the valve cover
Old 11-19-2009, 01:10 AM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
could it have over heated because of the leaky water pump?
After the engine cooled down , did it start back up?
Old 11-19-2009, 01:34 AM   #12 (permalink)
96 es300 2mz-fe
Unfortunately yeah..i was tryin to make it home but engine shut off, when i was less than a mile away from the house..I drove about 5 - 10 mins while it was overheating
Old 11-19-2009, 01:48 AM   #13 (permalink)
96 es300 2mz-fe
This is a video of the exhaust...is this white smoke? or should it be more than that?
Old 11-19-2009, 01:55 AM   #14 (permalink)
96 es300 2mz-fe
Ye it is overheating because of the water pump failing...there's basically no coolant in the system right now..as you put it in it goes straight out.It did start back up.
Old 11-19-2009, 02:03 AM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Where does the coolant come out?
