95 Camry Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2009, 08:42 PM   #1 (permalink)
View ashpathak's Photo Gallery
3rd Generation 95 Camry Oil Leak
My 95 Camry started dripping oil mostly from oil pump and timing belt cover. What is best way to repair it. Thanks
ashpathak is offline   Reply With Quote
Old 11-19-2009, 09:16 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Take a look at the timing belt / water pump replacement DIYs at DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 1 (part 1) and DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 2 (part 2). Replacing the oil seals is basically the same as replacing the timing belt, but just replacing a few more items in the process. Heck, if your timing belt / water pump is coming up for replacement soon, you might consider changing those out while you're at it.
Old 11-19-2009, 10:44 PM   #3 (permalink)
quangtran89's Avatar
iTrader Score: 8 reviews
View quangtran89's Photo Gallery
Sound like your leak is some what similar to mine. Mine was leaking crazy from the oil pump seal. While fixing that I decided to do the timing belt, water pump, and crank seal as well. At least now I'll know that area is taken care off.
quangtran89 is offline   Reply With Quote
