that is the Override for Automatic Shift Lock, usually there is a plastic plate covering it. once you take the plate out with a screwdriver there is a button underneath, once pressed it allows you to shift gears with engine off, e.g. for towing a broken car to the shop, or when you want to push a broken automatic tranny car, etc. otherwise it would sit ducks on Parking gear locked.
