Hey guys, The steering wheel on my camry is vibrating and I'm not sure what the issue is. It happens at all speeds and seems to calm more when I turn the wheel to the left some. It vibrates almost as if I had a flat tire. If anyone can tell me what to look for or what this problem sounds like I would really appreciate it.
Wheel bearing can have a grinding, growling noise that intensifies with weight (the bearing leaned on during a turn). So if you turn to the left (weight shifts to the right) and the noise lessens, turn to the right (weight shifts to the left) and the noise intensifies, maybe check the left bearing?
Jack up the car and try to shake the wheel at 6-12 o'clock and then 3-9 o'clock positions. You shouldn't notice any free play.
Ball joints? CV joints? Hub runout? Alignment?
Well I found what at least a majority of the problem is, my front left tire has a nice long bubble in it...Maybe I hit a nasty pothole or something.
I also checked/wiggled the tires from side to side and noticed a little play where the steering wheel would move slightly back and forth with it, i'm not sure if this is normal, but it almost seemed like the wheel isn't fully seated against the hub? I tightened the lugs double check. After doing this it seemed to have helped a little, but like I said I know that bubble is a majority of the issue.
Bubble on a new tire? What brand? There is a reason I use only Michelins (unless it's not available).
If you turn hard enough you can move the steering wheel a bit. So I'm not too clear if that's a problem there for sure.
Did you check the tie rods? That's where the steering rack hooks up to the knuckles (the large hunk of metal with the wheel hub). If you grab the tie rod itself and move it in/out/up/down/left/right, you should not feel any play. If it's the outer, it's easy to replace with free loaner tools from Autozone. The Raybestos with urethane bushing is about $30 online.
The tires are atleast 2yrs old. I haven't had a chance to check out any of this other stuff yet. I really appreciate the info, i'll post up more as I'm able to check.
Thanks again!
if steering wheel shaking/vibration happens at higher speeds (above 70-80mph) only and you cannot ehar any other noises mentioned above (wheel bearing, etc.) I would try re-aligning the wheels. that's what fixed such problem on a bunch of my cars developing same problems in past.
EDIT:
never mind, just read post about tire bubble. seems you've got it nailed down already. good luck man!
