5sfe Cams - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2009, 06:10 PM   #1 (permalink)
fastss's Avatar
View fastss's Photo Gallery
5sfe Cams
While doing my valve cover gasket on my 97 Camry, i realized the cams are really easy to change. I was wondering if i can get performance cams for it & if so from where?
I know they have performance cams for 5sfe mr2's, will these work also?
And what kind of tune if needed?
Daily Driver:1997 Camry LE: Fogs, 2 12" Pioneer Champions 760W Pioneer Amp, Infinity's on Kenwood 4chan, LED interior Conversion, Flowmaster, K&N Filter, 18" A/R wrapped in Continental's
fastss is offline   Reply With Quote
Old 11-20-2009, 10:18 PM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
Umm i dont think that they are peformance cams for the 5S. i know you can send your cams over to Webcamshafts.com and they will reweld regrind your existing cams. tuning i dont know too much about
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is online now   Reply With Quote
Old 11-20-2009, 11:53 PM   #3 (permalink)
fastss's Avatar
mr2 5sfe's do. i found a write up with it giving 42 more whp.
Old 11-21-2009, 05:31 AM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Do share with the class...
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 11-21-2009, 08:13 AM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
http://warp.scl.utah.edu/mr2/200rwhp5sfe.html
"The motor currently outputs 147 STD rwhp/153 STD rwtq as compared to the @105 HP and @125 tq of a stock n/a MR2. This was accomplished with larger cams (Webcams 294 grind intake, stock exhaust). The head was also ported and polished and had a 5 angle valve job. There is a custom built 4-2-1 stepped tube race header exiting through a 2.5" straight pipe. A few other performance mods include a Crane performace coil, an Apexi intake, and Jacobs spark plug wires. This is all being controlled by an Accel DFI gen 7 stand alone engine management system."
you need more than just a cam for what you were reading.......
^ and leaving it that way!
Old 11-21-2009, 02:46 PM   #6 (permalink)
Creeps228's Avatar
Yeah they only performance cams are the Webcams.com regrinds ones. you send your OEM camshafts and wait until they regrind and reweld them with a higher lobe longer duration
MR2: 7A-GE
Old 11-21-2009, 05:23 PM   #7 (permalink)
View Kenny_McCormic's Photo Gallery
Keep in mind you need to keep up on timing belts if you do this, otherwise you might find out the hard way you built an interference engine.
Kenny_McCormic is offline   Reply With Quote
Old 11-21-2009, 09:56 PM   #8 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
IMO why would you want a engine designed for low-end torque to rev high?
5sfe 7000rpms basically pointless
EDIT: i take that back this is
7700 rpms by the same guy!
i hope you get my point.
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 11-22-2009, 12:10 AM   #9 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Sigh, I wish I had a 5-speed in my Camry.....:-(
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 11-22-2009, 01:15 AM   #10 (permalink)
Let The Awakening Begin
Red_T_SwiftCam's Avatar
View Red_T_SwiftCam's Photo Gallery
http://www.youtube.com/watch?v=nc_Kiw7s1XY 5sfe 7000rpms basically pointless
http://www.youtube.com/watch?v=x2ltjFkzqiQ 7700 rpms by the same guy!
I don't. Cams push the power band specifically in this motor (MrT 763 Webcams) higher. In order to get the full use of the cams, higher rpms must be reached. Pointless i think not. A lot more to that 5sfe than just cams.
Red_T_SwiftCam is offline   Reply With Quote
Old 11-22-2009, 01:38 AM   #11 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $219005
View 92Camry5sp's Photo Gallery
What is the 5sfe tuned on to actually rev up to 7700 rpm? i wanna know more.
92Camry5sp is offline   Reply With Quote
Old 11-22-2009, 11:29 AM   #12 (permalink)
It actually involves extensive work opening up your Ecu and replacing the stock timing crystal of 16Mhz and soldering in a higher Mhz Crystal. The individual who Over clocked there Ecu is also running on SMt6 for extra tuning.
More http://www.mr2oc.com/showthread.php?...hlight=clocked
Old 11-22-2009, 05:04 PM   #13 (permalink)
My leather so soft
Gameroom cash: $104610
View the94camryman's Photo Gallery
http://www.importperformanceparts.ne...am-toyota.html
Webcam Triumph cams.
Mark
2000 BMW 328Ci
the94camryman is offline   Reply With Quote
Old 11-22-2009, 05:21 PM   #14 (permalink)
Bdub215's Avatar
alright then let me spell it out for you. FE<GE. the economy heads arent made for high reving. thats why none of them have redlines higher then 6500rpms. like i said before and this is my opinion making a 5s rev to where a 3sge revs is pointless to me. if you want the torque of a 5s and the ability to rev high do a 5sge because you atleast get the better head.
Old 11-22-2009, 05:34 PM   #15 (permalink)
FE<GE Thats a know fact. What im saying is also fact. Its a bit easier and maybe even cheaper to throw cams in a 5sfe, rather than tear down your motor find a 3s head drill a 5s block for coolant passages then throw it back in...... But what the hell do i know. OP Webcams is what your looking for.
