"Burned out tail light" Dash light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2009, 08:35 AM   #1 (permalink)
View Lightning Blue's Photo Gallery
4th Generation "Burned out tail light" Dash light
So the burned out light dashlight comes on after I start the car when I hit the brakes, then it stays on.
I replaced every bulb back there (four brake, two turn signal, two marker lights, two reverse lights) and it is still happening! Is whatever is doing the check for the burned out lights defective, and if so, is it easy/cheap to replace?
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
Old 11-23-2009, 10:01 AM   #2 (permalink)
Gameroom cash: $303255
Did you remember to check the high mounted "third" brake light? Many times people forget that one.
Mike
Old 11-23-2009, 10:09 AM   #3 (permalink)
View ruggz's Photo Gallery
This may be a coincidence but my car was doing the same thing but my check engine light was on also. I replaced the oxygen sensor and all the lights went off none of my tail or reverse lights were bad.
ruggz is offline   Reply With Quote
Old 11-23-2009, 01:37 PM   #4 (permalink)
Good point, I'll replace the high mounted brake light even though there's a nice LED bar on my spoiler making the high mounted one useless...
Old 11-24-2009, 07:40 AM   #5 (permalink)
Mike
This was spot on, it just so happpened to be the same as the reverse lights I replaced, popped one of those in and the light went out! Thanks
Old 11-24-2009, 08:21 AM   #6 (permalink)
You're welcome. Glad I could help.
Mike
