Picking the correct ATF for 00 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2009, 11:12 AM   #1 (permalink)
View ddagsyn's Photo Gallery
hi
I am trying to figure out the right transmission fluid for my 2000 V6 Toyota cmary that says Dexron 2 or 3 on the dipstick and as I read all the labels getting more and more confused. So I need some help in selecting the correct one from the Castrol website. If you have any other brand suggestion that is availabe let me know. Thanks
DEX/MERC DOMESTIC MULTI-VEHICLE
http://www.castrol.com/castrol/secti...tentId=7027043
IMPORT MULTI–VEHICLE
http://www.castrol.com/castrol/secti...tentId=7028224
DEXRON®–VI
http://www.castrol.com/castrol/secti...tentId=7028225
Thanks
ddagsyn is offline   Reply With Quote
Old 11-23-2009, 11:27 AM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
You can use the first or third one, but not the second one.
You can use anything that says it meets Dexron requirements. I personally use Valvoline Maxlife.
EDIT: It appears that the second one can also be used. See my later post for details.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-23-2009, 12:15 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Anything that meets Dexron III specs is fine. I typically run Walmart Supertech Dex III ATF, but if you've got money to burn, the first one you list will work fine. The new Dexron specs tend to be a bit lower viscosity (thinner) than Dex III -- usually you can use them, but I've heard of occasional shifting issues when using an ATF that meets the newer Dexron requirements in older trannys. FWIW.
Old 11-23-2009, 01:41 PM   #4 (permalink)
I am guessing you use the following valvoline product.
http://www.valvoline.com/products/br...ssion-fluid/37
Doesn't the Toyota dealership use Valvoline oils as well.
thanks
Old 11-23-2009, 02:59 PM   #5 (permalink)
View freeyellow2000's Photo Gallery
Any particular reason why you can't use CASTROL IMPORT MULTIVEHICLE (2nd one) ?
freeyellow2000 is offline   Reply With Quote
Old 11-23-2009, 03:14 PM   #6 (permalink)
'95 Camry 5S-FE
ddagsyn:
Yes, that is what I use.
freeyellow2000:
You can't use the second one because it doesn't state that it meets Dexron requirements, unless I missed something. Just because it says Toyota, doesn't mean you can use it. It must say that it meets Dexron reqs.
EDIT: Sorry, I didn't scroll down on the second one, so I missed where it said:
"General Motors DEXRON®–III H and prior (Not for use where DEXRON®–VI is required)."
So I guess it can be used.
Old 11-23-2009, 03:29 PM   #7 (permalink)
ddagsyn:
freeyellow2000:
thanks for your replies- On the topic of differential fluid drain and filler plug. Am I correct in assuming that on a 2000 V6 Camry the differential drain and filler is the same as the transmission drain and filler? That is there is no separate drain and refill on the differential?
I am planning to do only a drain and refill on my transmission. This is the procedure I am going to follow. Let me know your comments or advise.
- Secure the car on car ramps and secure the back wheels to prevent rolling. Parking brake is also set.
-Unscrew the transmission drain plug and let the fluid drain. I know this will not drain the entire transmission. Plan on doing this more frequently to get entire fluid refreshed.
- Screw the transmision drain plug (33ft/lb torque).
-From the filler dipstick hole fill in the amount drained. Plan on using Valvoline Max life ATF.
-Start/drive check for leaks and check dipstick level.
thanks
Old 11-23-2009, 03:35 PM   #8 (permalink)
'95 Camry 5S-FE
^ I don't know about the gen 4 v6, but the gen 3 I4 has a separate diff that requires a separate drain and fill. To check for yourself, either consult your Haynes manual (If you don't have one, get one), or crawl under your diff and look for a drain plug.
Old 11-23-2009, 07:15 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The first two are fine. The third one, Dexron VI, is iffy. While GM claimed that it's "backward compatible", they also issued a TSB on problems in older transmissions. So I think it would be safer to stick with the thicker "traditional" Dexron III type fluid.
Since GM no longer licenses out the Dexron III name, oil companies can only sell them as "compatible" fluid. It's still fine.
In addition to those two, WalMart's SuperTech DIII works fine. If you want a good value synthetic blend, try the SuperTech Mercon V. It's listed as DIII compatible and the formulation is approved by Ford.
Originally Posted by ddagsyn View Post
hi
DEXRON®–VI
Thanks
Old 11-23-2009, 07:20 PM   #10 (permalink)
No. I don't know when the change-over date was for the separate transmission/differential fills. But in 2000, the last days of the A540 series, I would think they only share the same dipstick tube for filling, but still have separate drains using the 10mm hex.
I don't know how mechanically inclined you are. But I'd actually recommend that you get a Fram ATF kit and change out the strainer/gasket. If not, just start with drain/refill. After 9 years you're going to have a layer of metal sludge in there (wear from friction and steel, like brake pad and rotor).
Old 11-23-2009, 07:27 PM   #11 (permalink)
Valvoline fluids are very good.
I'd add the differential part:
- Look for the differential drain plug on the back side of the differential, facing the firewall. (Use a combination of tools in the close quarters, combo wrench, adjustable wrench with the 10mm hex, if you don't have a short version.)
- Drain the fluid in the differential. Observe it's condition for own reference.
- Measure the amount with the fluid drained from the transmission pan.
- Add back into the dipstick tube.
thanks
Old 11-24-2009, 10:26 AM   #12 (permalink)
Regarding the differential - see last poster information in the link. I guess i will find out soon.
99 v6 camry differential fluid
Old 11-24-2009, 10:33 AM   #13 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I just use ATF-4 from the dealer in my '96, and do regular drain and fills.
5 Lug Corolla WHAT?
Old 11-24-2009, 05:29 PM   #14 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
If 99-01 camry V6 tranny shares ATF and differential fluid, then how much qts. is needed to be pour into the dipstick hole to fill both places? The last poster doesn't tell that.
ty**20 is offline   Reply With Quote
Old 11-25-2009, 08:18 AM   #15 (permalink)
I checked the Chilton manual last night and it just adds to my confusion regarding the differential. The manual in Section 1 sub 27 states that only 1999 Lexus ES 300 and later have the same drain and fill for the differential.
For the V4 the drain is separate from the filler and they have a picture of an actual engine showing that. (OK I agree based on the postings on the website)
HOWEVER on the V6 they show a figure of a differential and show a separate drain and fill tube. OK, I was convinced that the V6 2000 had a separate differential drain but where did the filler come from. Isn't the ATF for the differential filled from the dipstick?.
Thanks
