98 Camry Pulls Hard Left - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2009, 08:44 PM   #1 (permalink)
View tc9805's Photo Gallery
I hope someone can assist with a very bothersome alignment problem. The car is a 1998 Camry LE Sedan with 80k miles on it. I have been trying to fix this issue for over a month and have no indications whether I am going the right direction. The story line is as follows:
  • Tires had 40K plus miles and were hydroplaning badly
  • Had tires replaced with Yokohama Avid tires
  • Car started to pull left, and while the car was in the air I noted the Struts were all leaking
  • Had struts replaced with Monroe Sens-Trac Struts and car was aligned
  • Car still pulled hard to the left
  • Returned the car to the shop for them to address the pull and ensure the car was properly aligned.
  • Car was kept 3 days, struts were removed, all from end parts were inspected, tires were rotated, and different manufacture’s tires were installed on the rims and installed on the car.
  • The shop set the car alignment up more than 6 different ways. Car was set such that it should have driven off the road to the right as soon as the steering wheel was released.
  • Car still pulls left!!! Hard!!
The only possible thought the shop has is an issue with the rack. I will investigate any possibilities.
Thanks for any input.
tc9805 is offline   Reply With Quote
Old 11-24-2009, 10:11 PM   #2 (permalink)
Custom fab's my specialty
Leviathan66610's Avatar
View Leviathan66610's Photo Gallery
Yea I've kinda got the same problem but mines a gentle pull; sounds like yours is a bit more serious. It's time to consider things like rack n pinion, ball joints and tie rods. Also, a mechanic one told me the lower control arm bushings can cause that. Sometimes you just gotta do things yourself. Get under there and wiggle all the suspension components, visually inspect all the bushings. And if they all seem fine then it would have to be the rack n pinion
Leviathan66610 is offline   Reply With Quote
Old 11-24-2009, 10:24 PM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Has it ever been in a accident?
carsrus is offline   Reply With Quote
Old 11-25-2009, 12:11 PM   #4 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
may seem obvious, but are all 4 tires inflated to spec?
Admiral is offline   Reply With Quote
Old 11-25-2009, 02:03 PM   #5 (permalink)
Yea, the car was in a small skirmish before it had 5k on it. Car was purchased new by my mother and in the first year she was hit in the left front at an intersection. All records indicate it was simply cosmetic and not frame or suspension damage was sustained.
The shop concurred due to the readings the Hunter alignment machine was putting out. his was one of the first things I mentioned to the shop and investigated with my mother.
What is amazing is that if it was bent or damaged from an accident then the alignment should be able to compensate for the pull through over adjustment.
The other particular thing is the mechanic looked for any obvious bent or damaged parts and was not able to find anything he thouht could cause the problem. Of course he was not a Toyota expert.
Old 11-25-2009, 02:05 PM   #6 (permalink)
All tires were checked and are at the toyota recommended pressure.
Old 11-25-2009, 02:14 PM   #7 (permalink)
Thanks for this input. I will get the car up in the air and take a look at the lower control arms. Do you know of a technique to determine if the bushings are worn?
The tie rods and ball joints were checked more than once and all concur that they are tight and in good condition.
Old 11-25-2009, 05:59 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
Perhaps a brake is dragging on the left side?... stuck caliper piston or the caliper is stuck on the slider pins?
BMR is online now   Reply With Quote
Old 11-25-2009, 07:51 PM   #9 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
Do you have the sheet that the hunter machine printed off. My es300 (Camry) Pulls hard right, It pulls because of a worn out lower control arm bushing.
zppeacock is offline   Reply With Quote
Old 11-26-2009, 12:38 AM   #10 (permalink)
Usually if the bushings are bad something will be loose. But the best way to tell is simply to inspect for cracks or dry rotting. It's just like inspecting a tire or hose basically; rubber rots after so long and if the bushing are bad try to buy ones made of polyuethane. Supposedly it lasts forever without rotting.
Old 11-26-2009, 07:45 AM   #11 (permalink)
View NFSPD's Photo Gallery
I have the same problem was told it was the rack but not sure. Going to look into more this week. Will keep checking here to see what you find.
NFSPD is offline   Reply With Quote
Old 01-12-2010, 11:26 PM   #12 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
NFSPD,tc9805 did you guys find out any correlation between cracked control arm bushings and car pulling towards left/right? If so please post back.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 01-19-2010, 10:25 AM   #13 (permalink)
I apologize for mot replying sooner, I have been out of pocket and have not had a chance to get the car in the air. With the weather as it is currently I am trying to find time for further investigation.
When I attempt a fix the problem I will report back to update.
Old 01-19-2010, 12:00 PM   #14 (permalink)
I concure with your statements on the polyurethane version. I have experience in 740 Volvos. Once I have a chance to determine if these are the culprits I will advise.
Old 01-19-2010, 12:22 PM   #15 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
All,
Typically (as in almost always), cars do not pull from worn out parts like ball joints, tie rod ends, A-arm bushings, anti-sway bar bushings, leaky struts, ect. . .
Lets say the car was never wrecked or curbed hard but has 160,000 miles. Should it pull to the left or right with a normal alignment? No, all the parts wore out together. YES, it may drive like cr@p, and it might saw off your tires, and it might rattle your teeth but it probably wouldn't pull unless something else is wrong like, the right side A-arm bushing are damaged or missing as a result of someone mashing into the curb every Friday night for 5 years.
Also, It is the rightside of the car that almost always goes in the ditch and takes the most abuse (USA). Thus, the rightside could have a wheel set-back due to worn or damaged parts.
Check:
Rack - start car with front tires hanging in the air. Turn wheel back and forth and feel the difference. Does it trun easier one way than the other? A bad control valve in the rack or a leaky piston can create a pull. Or on a road with little traffic (safe place) and one which you know the car pulls on, place the trans in Neutral and turn the key off. Does it still pull?
Bad tires will cause a pull. You said this is the second set. Rotate the two fronts swaping them left to right and test drive.
This is not personal, just an observation; weak springs can allow the car to sag on one side and change the camber causing a pull. So can a heavy driver. Most shops seldom load the car as it is being aligned to simulate how it is used. Is this a factor? Measure the ride height empty and with you the driver in the car!
Alignment -
Excessive difference in Camber, caster, and wheel set back can make a car pull. Excessive toe out can be an issue when you stand on the gas creating torque steer but will not make the car pull when set to spec.
Typical alignment which works well on crowned roads daily driver:
Left - - - - - - - - - - Right
Camber 0.0 deg 0.0 to -.25deg
Caster 3.0 to 3.5 3.0 to 3.5deg
Setback 0.00 0.00
Toe = ZERO, to slight toe-out 1.5mm max
Thrust line, not a big deal a on front wheel drive car. Lots will look like crab going down the road and makes centering the steering wheel a pain.
FYI: I suspect if there is no damage to the lower A-Arm or strut but the car has some set-back on the right front you could loosen the craddle bolts push the right side ahead or pull the left side back. Get a tape measure and crawl under the car. Measure from equal anchor holes in the cars sub-frame to the lower ball joints. Both sides should be an equal length.
Let me know if you have any questions. Oh and post up the before and after alignment numbers if you have them. Also have the shop check the toe-out on turns to confirm you don't have a bent spindle or strut assembly.
Its fixable. Give us some info. . .
Good luck.
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
peshwa (01-19-2010)
