led help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2009, 06:06 PM   #1 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation led help!!
ok so i have custom led strips (audi inspired) under my headlights and parking lights. now i also have led fog lights (will upload pics later) mix all this with my hids and its a little over kill so what i wanna do is have the fog lights stay on with hids but i want the audi leds to cut off when the head lights come on. Could i do this by hooking the ground of the audi leds to the power of the head lights? or would that ruin the led strips? please help! yes i know just hook it to a switch but i just want it to be automatic off you know?
chris
Spitfire is offline   Reply With Quote
Old 11-25-2009, 06:32 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
try PMing ASG14. hes a wiz with that stuff. wired up the fogs on my car better then the factory could have.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-25-2009, 06:41 PM   #3 (permalink)
JDM Inspired
Spitfire's Avatar
i dont think i would have to even pm him. I think the word LED in the thread title will suck him in =]
Old 11-26-2009, 12:46 AM   #4 (permalink)
Custom fab's my specialty
Leviathan66610's Avatar
View Leviathan66610's Photo Gallery
So let me get this straight, you want the front leds to stay on at all times but cut off only when the headlights come on? The turn signals and brakes won't be a prob but imo a switch is the only option.
Leviathan66610 is offline   Reply With Quote
Old 11-26-2009, 01:47 AM   #5 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
just put a switch on the LEDs like i did. so i can control my LED angel eyes when i want it on or off
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 11-26-2009, 07:39 AM   #6 (permalink)
Camry: 94-I4 and 94-V6
View sintox's Photo Gallery
Canada
chris
No you should never do this kind of try-and-error. You'll blow a fuse if you're lucky.... You'll melt some wire somewhere deep in a bunch of other wire-harness if you're less lucky.
I've bought a relay from my local electric store for less than $5.
Buy the one with 5-pin, not 4.
The 4-pin relay has 2 options (you'll ignore 1 of the pins):
option 1) power on: relay output is in open-circuit (switch OFF).
option 2) power on: relay output is in close-circuit (switch on).
You'll use option (1) for what you describe: when power on (the relay input and the head-line wires are in parallel), then the relay output is switched OFF (relay output is in series with your angel-eye, so angel eye is OFF).
sintox is offline   Reply With Quote
Old 11-26-2009, 01:36 PM   #7 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
no the leds come on with my parking lights. When i switch from parkin lights to headlights i want the led strips under my headlights to auto cut off if that makes sence.
Old 11-26-2009, 01:37 PM   #8 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
I guess i could i just wanted it to be more automatic if that made sence ha If i couldnt figure out a way to do it like how im lookin for then i was just gonna hook it on a switch
Old 11-26-2009, 02:57 PM   #9 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
why dont you use maybe a relay kill the parking lights when the headlights are powered on
like the same idea of a starter kill but with lights
Old 11-26-2009, 07:38 PM   #10 (permalink)
View Dick Tuck's Photo Gallery
The relay mentioned above will work fine. What you want is a "single pole, double throw relay" Just put it in series with the line you use to power the LEDs and connect it so the you use the two contacts that are "normally closed" when the relay gets NO power. When the relay is powered from the headlight power lead the relay will DISCONNECT the led power by moving the contact to the position you have nothing connected to. The relay should have an internal wiring diagram on the case which should explain it all to you.
Dick Tuck is offline   Reply With Quote
Old 11-27-2009, 12:27 AM   #11 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
the12volt.com ....sign up and ask!
'07 Honda Ruckus Big Bore
Old 11-27-2009, 08:25 PM   #12 (permalink)
JDM Inspired
Spitfire's Avatar
well sorry to say its all gettin hooked up to a switch. Because im doing another idea =] stay posted!
