No Start '92 2.2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2009, 04:05 PM   #1 (permalink)
View mvftw's Photo Gallery
3rd Generation No Start '92 2.2
This is a spare car, only started once a month. 170k. Last week, no start. I thought I was chasing a fuel pump problem because I didn't hear the pump prime. After a couple of guys here said to jumper +B & FP, it does turn on. I spent the day troubleshooting...I checked the Open Circuit Relay, is check good. I loosened the top line on the fuel filter and I have fuel there. So I'm thinking it's not a fuel problem. The plugs are dry (I thought they would be wet). I checked for spark. I have spark (yellowish, maybe weak). I checked the coil & pickup, both tested Ok. The Igniter is Ok I think because the tach moves just a little when cranking...Can the distributor still be bad???
mvftw is offline   Reply With Quote
Old 11-28-2009, 04:26 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
If you've got dry plugs, you've got a fuel problem.
Did you try JohnGD's suggestion in your original thread at Fuel Pump??? ?
Old 11-28-2009, 05:04 PM   #3 (permalink)
Sort of...I cranked the car with the top fuel filter loose, and it came out strong. That's why I'm thinking it's not a FP/fuel problem, but maybe the injectors are not getting a signal to turn on...
Old 11-28-2009, 05:55 PM   #4 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
does it crank?
you double check all fuses?
Old 11-28-2009, 08:43 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
If you have a voltmeter, you can check for reference voltage on the injector harness connectors. Should be +5V. Remove the connector and turn ignition to "on". Attach the negative probe to the engine block or chassis, then use the positive probe to check for your +5V.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 11-28-2009, 09:39 PM   #6 (permalink)
View supercharged3.0's Photo Gallery
Did you have any problem with the coolant temp sensor? That might be the problem
supercharged3.0 is offline   Reply With Quote
Old 11-29-2009, 05:30 PM   #7 (permalink)
3rd Generation
Question...If I have spark (maybe weak) can the Igniter be still be at fault or any spark the Igniter is good...Also can the coil still be bad if it ohm's out Ok, including the pick up...
Old 11-29-2009, 09:53 PM   #8 (permalink)
Certifiably Insane
96paseo's Avatar
If your getting spark ,the igniter is doing its job. Weak or good spark will depend on the coil. Yes, the coil can ohm out fine. Any cracks in the resin packing or plastic, especially near the high tension lead can result in spark leakage. If it's got cracks, replace it. Its a good idea to ohm out the pickup coils while testing the ignition coil.
Old 12-04-2009, 10:21 AM   #9 (permalink)
3rd Generation
Guys, thanks for all your help...finally got around to it and it was the distributor. Even-thou it ohmed out good, it wasn't...
