Stronger oil leak after tune up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2009, 11:01 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I did a tune up which included seafoam in the vacuum and oil. Only drove about it for 50 miles. I changed plugs, wires, distrib cap and rotor and all filters.
I already had a small distributor leak, but now it's larger. I was going to tackle the distributor o-ring myself but didn't want to mess with the timing. I put on the new rotor and cap and now the oil is leaking harder.
Now here is the weird part: I'm leaking from the middle-left side of the engine. It leaked here months ago, but that was from the camshaft seal that was replaced with the timing belt (along with all the other seals in the area). I'm not sure what this could be. Power steering? How do I tell the difference between power steering and oil?
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 11-30-2009, 11:38 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
PS fluid is more-or-less clear ATF fluid (actually, a lot of folks, including myself, run ATF in the PS system...the downside is that telling apart a tranny leak from a PS leak will be a bit of a problem, if and when).
Open up your power steering reservoir. Put some on some white paper. Take a sniff. Compare to oil...
Put some white paper under the area that is dripping. Compare...
Old 11-30-2009, 11:46 PM   #3 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i would try to clean up the eng bay and take a look a few days later for the leak
Old 12-06-2009, 01:11 AM   #4 (permalink)
View supercharged3.0's Photo Gallery
put some LUCAS oil additive
supercharged3.0 is offline   Reply With Quote
Old 12-06-2009, 01:15 AM   #5 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
ahh and the only reason i will never use seafoam
the o ring on the distributor is easy just put it in the way it came amd mark of wich wires go where you could even get away with orange rtv around the original oring
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
