Quick: I need an answer right now! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2009, 03:34 PM   #1 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
When I drain my 96 2.2 4 cyclinder's transmission (through pan and cooling hose) along with my differential...how many quarts of fluid do I need to add back all together.
I went and bought 10-quart bottles and the rep told me its going to be waaay too much.
I couldn't find an exact answer anywhere.
96ToyoCam164K is offline   Reply With Quote
Old 12-01-2009, 03:41 PM   #2 (permalink)
View DAT RICE's Photo Gallery
because u didn't use the search button. There are diy threads on both tranny and differential flush. Both tell you the amount needed
DAT RICE is offline   Reply With Quote
Old 12-01-2009, 03:59 PM   #3 (permalink)
How could I miss that
Ok I'm not asking anymore questions on this project...and just get to work and read the instructions 100 times if I have to
Old 12-01-2009, 09:30 PM   #4 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
96Toyo just relax and take your time.
i have yet done a tranny oil change/diff so im not sure. but i have read if i remember correctly it should be about 4 quarts when you drop the pan. then once you disconnect the cooling hose just repeat process until you see clean oil come out. not sure how much/long it would take but i would think no more than 10qts
Old 12-02-2009, 04:07 AM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Drain and refill is 2.6 quarts. Diff is 1.7 quarts.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
