V6 axle replacement tips (caution - 3 pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2009, 07:21 PM   #1 (permalink)
'94 V6 Auto
View Kevin89AllTrac's Photo Gallery
V6 owners don't have to deal with axle shafts stuck in carrier bearings, but I found a couple of caveats when replacing axles, especially if don't have an impact wrench. First, before you put the car in the air, take the cotter pin and castellated cap off the axle and loosen the axle nut. Just crack it loose an eighth turn or so with a 1 3/16" socket (30mm?) and breaker bar. Use a piece of pipe over the breaker bar if you have to. A standard depth socket worked fine on my non-ABS car. If you can't budge it, buy an impact wrench or take it somewhere with an impact wrench. DO NOT drive or even roll the car with the nut loose - the wheel bearing will be ruined, fast.
Second, after the car's in the air and the wheel is off, break the 8mm inner joints bolts loose. If you can't get them loose or - worse - you round them out trying to get them loose, put the wheel back on and take it to someone who can get them loose. BMR suggested lots of 1/2" extensions and a breaker bar and it works:
Clean any crud out of the hex bolt heads. Just take a small screwdriver and scrape it out. Then stick the hex driver in the bolt and attach enough extensions so you can swing a breaker bar outside the wheel well. Before you put the breaker bar on, take a small sledge hammer and whack the extension face-on. You want to shock the bolt so any rust on the threads gets broken. Don't be shy, hit it hard. You won't bang up your extension too bad. Then put the breaker bar on and TIGHTEN the bolt. See if you can feel the threads break loose. If you can feel it break then it will loosen easily. The reason for tightening it first is that if you're going to round out the bolt, you want to round it out the opposite way - righty tighty - rather than risk rounding it out so it will never come out except with a cutting torch.
BMR suggested to use a 1/2" drive hex socket, about 16 bucks. That's the right thing to do. I'm cheap and got away with a $4.99 "Brake Caliper Tool Set" from Checker/O'Reilly. 3/8" drive but supposedly for an impact wrench (they're black anyway) and it includes an 8mm hex socket. I used a 1/2 x 3/8 adapter on the 1/2" extension:
If you're lucky and get all of the hex bolts loose, take off the tie rod and the three control arm nuts/bolt out to get the room to remove the shaft. The tie rod end came off after I smacked the side of the casting with a sledge hammer, put the castellated nut on to protect the threads, and tapped the nut with a hammer. No need to unbolt the sway bar like the manual says.
Considering the lack of quality of reman'd axles (lifetime warranty or not), make it easier remove it next time by putting some oil on the tie rod taper before you put it back together, and torque the hex bolts to factory spec (48 foot pounds) so they come back out when you want them to:
Kevin89AllTrac is offline   Reply With Quote
Old 12-01-2009, 11:47 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
some decent advise there for people without an impact gun
but considering how handy an impact gun is when working on a car and how cheap they are these days.... :shrug:
HaHa
Old 12-02-2009, 12:15 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349453
View BMR's Photo Gallery
Aye, that's the ticket! Only too happy to help.
BTW, I had gawd-awful luck with reman'd axles from Cardone. The first pair, the driver's side was good but the passenger's side clinked when making a hard left turn. The second reman'd axle made louder crunching noises on turns AND had a vibe at speed. The third time, Carquest (where I bought them) gave me a new Cardone for the same price. That one was good. Finally. I got pretty fast at changing 'em out! Funny thing is, they didn't ask me which I wanted when I picked 'em up and I didn't think to ask about it. If they had, I probably would've paid the extra $15 or $20 for new ones rather than reman'd.
I hope your luck with the Fenco's is better! (I read your other thread.)
BMR is online now   Reply With Quote
Old 12-02-2009, 10:49 AM   #4 (permalink)
'94 V6 Auto
I'm pretty sure the new Fenco/Powerline axle I bought was built in Zhejiang, China by Guansheng Auto Parts (GSP.) GSP bought Powerline, an axle remanufacturer, in South Carolina. The South Carolina factory still remanufactures parts but GSP is using it as a distributor for its new parts too. GSP is an OEM for several car companies.
From what I can tell, Cardone axle remans come from Matamoros, Mexico, but their new axles are almost certainly built in China. Apparently US and Canadian remanufacturers were getting killed by inexpensive, new parts from China so the remanufacturers either got bought-up by those Chinese manufacturers or are buying product from China to stay in business.
I'm happy to buy a new (vs. reman'd) part if it's any good. It just seems that a brand new $60 axle is too good to be true, but China has some pretty good technology and dirt cheap labor.
