92 camry trans problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2009, 08:03 AM   #1 (permalink)
View 92_TOYOTA_CAMRY's Photo Gallery
Hi everyone,
I'm having problems with my camry. We just changed the timing belt and the car was running fine. Then a couple weeks later the car wouldn't shift into drive. It shifts into reverse and park, but after that nothing. I was thinking maybe it could be the transmission, but it was driving fine a couple days ago. Could it be something else? Maybe wiring or solenoid?
Thanks
Amy
92_TOYOTA_CAMRY is offline   Reply With Quote
Old 12-05-2009, 08:30 AM   #2 (permalink)
View Kenny_McCormic's Photo Gallery
Check for codes? Does it go in manual low/2nd?
Kenny_McCormic is offline   Reply With Quote
Old 12-05-2009, 08:34 AM   #3 (permalink)
The tranny only shifts into park and reverse. When I shift it to neutral, it's ok. But the problem is after that, it won't go into drive or 1 and 2. It's like stuck in neutral or something.
Old 12-05-2009, 11:57 AM   #4 (permalink)
Will the stick physically select D/2/1? Does it feel right when shifted in D/2/1? Maybe you have a cable hanging up or something.
Old 12-05-2009, 02:14 PM   #5 (permalink)
Well when shifting it doesn't even like it's shifting. When I put down it neutral and shift down again to drive and to L1 and 2, I don't feel anything shifting. Like it can only go up to neutral, then after that it doesn't shift anymore.
I can put the stick though to 1 and 2 and drive but the car doesn't feel like it's shifting and doesn't move. OH and about the cable? What do you mean it may be hung up?
Thanks
Amy
Old 12-05-2009, 06:12 PM   #6 (permalink)
Trans full of fluid?
Old 12-08-2009, 09:05 AM   #7 (permalink)
It was leaking but it's now fixed
