DIY Need a how to for changing front brake pads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2009, 12:28 PM   #1 (permalink)
View armaniran's Photo Gallery
3rd Generation DIY Need a how to for changing front brake pads
first time wanting to do my front pads myself so i need some help with the steps if there's any DIY how to's anyone can tell me that be great
thanks
and maybe flush the break fluid since its turned black
armaniran is offline   Reply With Quote
Old 12-05-2009, 12:56 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Brake Pads
DIY: Gen 3 Front Brake Pad replacement
Brake Fluid
DIY: 1996 Camry Brake Fluid Flush Procedure (GEN3)
Websites for DIY
Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
thanks
bdy0003 is online now   Reply With Quote
Old 12-08-2009, 01:08 AM   #3 (permalink)
thanks for the links i appreciate it, but how do i know if i have to replace my brake fluid, its black color right now,
Old 12-08-2009, 02:20 AM   #4 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Brake fluid should be about the color of vegetable oil. Clear-ish yellow.
Mine right now is black-ish green. So anything that dark should be changed.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-08-2009, 04:33 AM   #5 (permalink)
View gottarollwithit's Photo Gallery
Anything that's not yellowish clear or translucent blue needs to be changed. Make sure your system is in good/sealed condition so it's not letting crap contaminate your fluid.
Yellow is DOT 3/4 as i remember. You might be able to switch to ATE blue - the DOT 3/4 compatible kind.... i think... Regardless, flush all of that old bad fluid out. Clean up your calipers/pistons, lube it, pop some pads in and resume making asphalt tearing stops.
gottarollwithit is offline   Reply With Quote
