93 3vz cam seal and crank seal pn - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2009, 01:11 PM   #1 (permalink)
View charley240sx's Photo Gallery
hello everybody, i will be repairing a lot of my motor really shortly, and this is my first time doing something so labor intensive.
i will be replacing the following
-waterpump
-belts
-tensioners
and need the part numbers for the cam seals, and crank seals from toyota.
if there is anything else that should be done, please advise so.
thanks all
Charley
charley240sx is offline   Reply With Quote
Old 12-06-2009, 04:00 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Head on over to http://www.toyodiy.com/parts/ and look up your rig -- should be able to pull the part numbers for the cam and crank seals. I'd also recommend doing any oil seals in the oil pump (oil pump gasket, o-ring, oil pump seal).
Old 12-06-2009, 06:30 PM   #3 (permalink)
well, see thats where im unsure. with all the diagrams ive looked at, im kinda unsure which are the cam and crank seals. ive never done this before so im unsure of what part i should be looking at. same applies to the oil pump.
Charley
Old 12-06-2009, 06:42 PM   #4 (permalink)
ok, just looked at toyodiy, but am still uncertain which parts are the cam seals and crank seal, if someone can tell me, i would really appreciate it.
and for the oil pump assembly stuff, the only part that i could tell that may need replacing is the 15100C part, what are the other parts that you speak of?
Charley
Old 12-09-2009, 11:43 AM   #5 (permalink)
anybody?
