Originally Posted by ghost111
Can anyone tell me there is supposed to be a "woosh" sound when you remove the gas cap? I do not hear it and it seems there should be.
You should be able to hear a "woosh" when removing gas cap after car has built up enough pressure and you don't have a leak. I have a 1991 Camry and I definitely hear the "woosh" sound but this is OBD-1 and there is no check for this.
Did you check the vapor pressure sensor? It is located on the top of the cannister not far away from the VSV. The following procedure is out of the service manual:
INSPECT Power OUTPUT OF VAPOR PRESSURE
SENSOR
Turn the ignition switch ON.
Disconnect the vacuum hose from the vapor pressure
sensor.
Connect a voltmeter to terminals PTNK and E2 of the
ECM, and measure the output voltage under the following
conditions:
(1) Apply vacuum (2.0 kPa (15 mmHg, 0.59 in.Hg)) to
the vapor pressure sensor.
Voltage: 1.3 – 2.1 V
(2) Release the vacuum from the vapor pressure sensor.
Voltage: 3.0 – 3.6 V
(3) Apply pressure (1.5 kPa (15 gf/cm2, 0.22 psi)) to the
Voltage: 4.2 – 4.8 V
Turn the ignition switch OFF.
Reconnect the vacuum hose to the vapor pressure sensor.
