Signs of fuel pump problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2009, 11:27 PM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Yesterday something odd happened that reminded me of other odd occurrences a few months ago. My gas tank was close to empty, so I filled up with ten gallons of gas. When I started the car, the car shuddered for a moment, the rpms were very low, then they shot up as normal to about 1,200 and then dropped down to a steady 800 or whatever it's usually at. The shuddering reminded me of a choking or misfiring engine, if you know what I mean.
A few months ago, I'd say this happened about three times: I'd be filling up with the car still running. My friend is inside the vehicle, so she told me what happened. I didn't hear anything odd from the outside. During the fillup, the car's rpms go up and begin to jump up and down, and it revs erratically. One of those three times when this happened, the car stalled during the fillup.
Is this a sign of something going bad? Maybe the fuel pump? Maybe a sensor?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-07-2009, 08:09 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
maybe the fuel system need the fuel cap on for emissions systems?
i have an extra fuel pump from my v6, i'll sell it to ya for a deal
^ and leaving it that way!
Old 12-07-2009, 01:16 PM   #3 (permalink)
I'm not sure what you mean by that. ...fuel cap on?
Old 12-07-2009, 01:19 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Are you getting any of the "classic" signs of low fuel pressure, such as cutting out at high speeds?
My first thought was that you might have a lot of crap in the fuel tank, and when you fill up when you're running on fumes it gets stirred up and sucked into the fuel system. Generally, 'tho, that causes a permanent problem (clogged fuel filter or injectors). Maybe you're lucky / unlucky enough to have "finer" sludge?
What it really sounds like is air getting into fuel system. I could sort of see that happening if you're filling up when the rig is running, but, offhand, I can't see how it would happen when the rig isn't running when you fill up.
Sorry I don't have a good diagnosis...
Old 12-07-2009, 01:41 PM   #5 (permalink)
Nothing whatsoever. I don't even consider THIS to be a problem, yet. More like, symptoms of a problem to come.
I'm currently using a Fram filter that I put in last year. At that point, the car was still using it's original filter. I have a new OEM filter that I may be putting on this week. I've read bad things about aftermarket fuel filters. I'm unsure if the Fram filter could be the cause of this.
I would say maybe the stuff that happened a few months ago could have been caused by the car running... and I should just turn it off when I'm pumping in gas. But prior to that, I had done the same on numerous occasions, without the weird RPMs or the stall. And yes, this last time, the car wasn't even running, and the shuddering occurred on startup, which made me concerned.
Any idea how difficult it is to take down the gas tank?
Old 12-07-2009, 02:09 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
First thing is Fram fuel filter should not be causing any issue.... the filter is too simple of a component to foul up. Filter life though may be shorter than the OEM, but I do not think that to be an issue.
The engine when running will activate the charcoal canister VSV to purge the fuel vapour using your engine vacuum at the intake manifold.
You basically experienced low vacuum (leak out the gas filler).
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-07-2009, 02:48 PM   #7 (permalink)
So you think the filler tube is faulty?
Old 12-08-2009, 02:24 PM   #8 (permalink)
Lightbulb
Any more ideas?
Old 12-08-2009, 07:21 PM   #9 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Its probally not the filler neck.
Easiest solution: Dont fill up with the car on lol.
carsrus is offline   Reply With Quote
Old 12-08-2009, 07:42 PM   #10 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
^ yea seriously? isn't it common knowledge on safety to never have the car running when you fill up?
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 12-08-2009, 09:11 PM   #11 (permalink)
That doesn't explain or help me with the recent oddity of the shuddering on startup AFTER the fill-up.
If that was indeed due to low vacuum, how would I confirm that?
Old 12-08-2009, 09:18 PM   #12 (permalink)
I can't think of anything that could go wrong by pumping gas with the engine running. Not that I smoke, but same thing with smoking and pumping gas. I mean, yes, flame + gas vapor is a nono... but I guarantee you will have a difficult time to get gasoline to light with a cigarette even if you seriously tried.
Nevertheless, that wasn't part of my question, and it isn't an every day occurrence. That fact is that I have done it in the past, and I have done it not long ago, and only those last few times did the RPMs jump like they did... plus the stall.
I'd rather fix this now, not later when something completely fails at the worst possible time/place.
Old 12-08-2009, 10:30 PM   #13 (permalink)
hill8570's Avatar
Run the car with the engine warmed up and the gas cap off.
Old 12-09-2009, 12:14 AM   #14 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
did you replace your fuel filter?
RU2CHKN is offline   Reply With Quote
Old 12-09-2009, 12:18 AM   #15 (permalink)
Nope.
I did last year with a Fram. I mentioned I was gonna replace it again this year with an OEM filter.
