Spring Compressor Recs?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2009, 05:55 PM   #1 (permalink)
View gottarollwithit's Photo Gallery
Looks like i'm replacing struts on all 4 corners soon. I've read the DIY tutorial on it, but don't have a spring compressor.
Anybody know of a good spring compressor that's not going to break, stretch, or result in horrifically injuring me? Any advice on which type/brand to buy? Snap on offers one made by bluepoint, but i don't trust cheap Chinese tools to not injure me, especially with this application. I'd like to use an impact gun on the spring compressor as well to speed things up.
The DIY Strut replacement shows the use of two individual spring compressors. Is this optimal?
DIY: Gen 3 front struts
Thanks!!
gottarollwithit is offline   Reply With Quote
Old 12-07-2009, 06:27 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
id go with ones like ASG has in his thread. they clamp onto the spring to prevent the compressor from flying off, resulting in rapid decompression aka...bad day.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-07-2009, 07:41 PM   #3 (permalink)
The guy with a maroon 92
n3rdifed's Avatar
View n3rdifed's Photo Gallery
yes, those spring compressors were almost exactly the same ones i used to take off my springs.
maybe if you know somebody else that does work on their car then you can borrow them...
n3rdifed is offline   Reply With Quote
Old 12-07-2009, 08:18 PM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I've always used the $13 ones from Harbor Freight. Just use a ratchet, not an impact wrench, and don't be an idiot and you're fine. Also, they come with hardware to clamp onto the springs so that they can't fly off.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-07-2009, 08:24 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
You can use the Autozone Free Loaner tool #OEM27036.
http://www.autozone.com/autozone/ino...gAndSuspension
If you don't want to buy the Sears 90500 type. The AZ one appears to be a copy of it.
www.sears.com
The TN DIY uses something similar to KDS3387.
Look up on www.sears.com
Because I dont' think you would need anything like the Strut Tamer:
http://www.otctools.com/newcatalog/p.../6580_2391.jpg
Old 12-07-2009, 11:00 PM   #6 (permalink)
OK, let's take this a different route. Clearly, the two individual spring compressors is the way to go. However, which spring compressors of this type do you guys own, enjoy, and feel safe using?
I've seen reports of poorly made spring compressors stretching and getting locked in place, requiring the use of another method of compression just to free the broken spring compressors.
What do you guys think of OTC tools? I've never even heard of them, are they any good?
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
I'm between the model above, the Sears stuff mentioned earlier, and maybe a used Strut tamer if i can magically get a killer deal on it.
Old 12-08-2009, 01:27 AM   #7 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
+1. im a cheap a** ... just take your time.
Old 12-08-2009, 04:19 AM   #8 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Just within the last two weeks, I used the one available for rent (free, pay/return) through Advance Auto Parts. Similar to the ones in the write-up, as they are two separate units.
We used an impact gun with them. Just be careful not to get the socket stuck against the spring (as it compresses). It's a bit annoying.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-08-2009, 04:28 AM   #9 (permalink)
Oh, don't get me wrong, i'm one cheap mofo as well. Why do you think i'm wrenching in the first place? However, i know that i'm not the greatest wrench around and because of this i tend to be very hard on my tools.
I also know that if i run a cheapass spring compressor and it jams or lets loose and damages stuff (including me) in the process, doing all of this work myself will have basically become a lost cause. I'd like to buy one good spring compressor once. I go cheap on a lot of tools, but i'm not gonna cheap out on something that can potentially cause big time damage.
Being able to use the impact gun on it is a big plus b/c i'm going to be doing this job on limited time.
Any thoughts on the OTC, Sears, or KD tools compressors??
Old 12-08-2009, 11:05 AM   #10 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
autozone ftw!!!! spring compressors aren't used too often, so i normally just spend my money on some other project that i'll never finish
^ and leaving it that way!
Old 12-08-2009, 06:13 PM   #11 (permalink)
View flyeri's Photo Gallery
Get them form Advance Auto or Auto Zone as previously described. I have used them twice and had no problems. It The air ratchet or impact driver will speed things up but don't expect to set world records. It still takes a little time and I think hand wrenches are actually easier because of the socket binding on the spring.
Just be sure that the ones you get have a latch that secures them on the spring in some fashion.
flyeri is offline   Reply With Quote
Old 12-09-2009, 12:48 AM   #12 (permalink)
Sears or KD first. Then Free Loaner or OTC. OTC buys a lot of tools from the lowest bidder around the world. Many are imports. Some are US made/assembled. You can get fleaBay deals that look identical, even the blow-mold case.
The parts store free loaner tool program I'm sure will work too. In fact, I think the OTC one looks exactly like the Autozone free loaner. My guess is both of these (OTC/Free Loaner) are made off-shores. The one disadvantage with free loaner is that some tools look kinda beat up.
Craftsman has ACME threads easier to turn (not sure about Free Loaner/OTC). Lube the threads with oil before starting. You may need to arrange the individual compressors to minimize interference with the nuts (but always opposite sides of each other). It works, so no need to get a Strut Tamer for the occasional job or on light weight sedans. Of course until you get into heavy duty truck/SUV springs, then just pay a shop to assemble.
Old 12-09-2009, 06:30 AM   #13 (permalink)
Ah, i had no idea OTC might be the same as the other mfg's. Their 2 piece spring compressors look identical to other brands... Man, i almost bought an OTC earlier today.
I'll see what else i can find. Is KD a reputable mfg?
Old 12-09-2009, 08:37 PM   #14 (permalink)
I'll say get the Craftsman one, if you're not willing to use Autozone's free loaner.
Yes, KD is a reputable brand. Like Craftsman, Kobalt and others, it's made by Danaher.
http://www.danaher.com/business/stra...ail.asp?key=12
Stanley Works and Snap-on are two others that make up the top three in the US. I personally prefer old-time Stanley-made Craftsman over today's Danaher-made Craftsman. Too bad I guess. But those who got old-time Snap-On made Kobalts at Lowe's are lucky. Snap-on tools are great, but beyond what I'm willing to pay.
Some of Danahers other major brands are:
Allen
Armstrong Tools
DTG Government
DTG International
DTG OEM
Gear Wrench
Holo-Krome
Iseli
KD Tools
Matco Tools
Sata
Spline Gauges
Old 12-12-2009, 10:24 PM   #15 (permalink)
John, thx for the info.
I think this is what i'm gonna use:
http://www.foxruntools.com/coilsprin...-kdt-3387.aspx
KD tools spring compressor - pretty much looks like the one used in the tutorial.
