Vibration from third brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2009, 06:04 PM   #1 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
So whenever I turn up the bass, the rear deck rattles and when the third brake light plastic hits the glass it makes this really annoying sound that's louder than the bass itself.. is there any way to fix this? I was thinking maybe some sort of thin trim that I could stick on there?
iovaykind is offline   Reply With Quote
Old 12-08-2009, 06:20 PM   #2 (permalink)
View flyeri's Photo Gallery
Rubber cabinet door bumpers. Come in clear at Home Depot. Stick one on the glass so the bezel sits against it.
flyeri is offline   Reply With Quote
Old 12-08-2009, 06:20 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Anything rubber or soft can be put in between them.
Chris Crash is offline   Reply With Quote
Old 12-08-2009, 06:42 PM   #4 (permalink)
quangtran89's Avatar
View quangtran89's Photo Gallery
I'm having the same problem. I pretty much gave up on it and just keep my bass down now.
quangtran89 is offline   Reply With Quote
Old 12-08-2009, 08:27 PM   #5 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
3rd Generation
I Couldnt stand it! I had to put a stop to that immediately. Very annoying. My bass dont go down.
4Cyl'erThriller is offline   Reply With Quote
Old 12-08-2009, 09:34 PM   #6 (permalink)
iovaykind's Avatar
The bass must stay on! Padded tape would be my "free" option but it would look a little off. Really don't feel like spending 5 bucks just to get a couple of clear rubber bumpers. What did you do about it cleanwhitecamry?
Old 12-08-2009, 09:38 PM   #7 (permalink)
93 Camry LE 5S-FE
I used a piece of rubber insulation from the 0 gauge wire for my amp. 4 or 2 gauge should work too.
Old 12-09-2009, 01:49 AM   #8 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i tried rubber/paper/foam etc etc... some work better than others but i ended up just removing whole 3rd light
Old 12-09-2009, 06:20 AM   #9 (permalink)
iovaykind's Avatar
Didn't that look funny though? Or did you fix it up..and doesn't that make the dash light go off if you don't have the third light?
Old 12-09-2009, 06:56 AM   #10 (permalink)
93 Camry LE 5S-FE
Yes, that will set off the dash light. I am currently investigating a couple of options for taking out the third brake light and replacing with some other light. or led strip or something. Ill let you know what I find.
Old 12-09-2009, 08:27 AM   #11 (permalink)
iovaykind's Avatar
I've looked into it too but I don't see any other way to deal with it because the dash light goes off if the wrong wattage is reported meaning using LED will still cause the light to go off :/ the only option I could think of was to completely move the third brake lift but that's too much of a hassle for a light
Old 12-09-2009, 11:10 AM   #12 (permalink)
it doesnt look funny. yea theres a gap where the light use to be but no more annoying vibe sounds
plus u cant see that theres a gap (outside of car lookin in) because of tinted window
Old 12-09-2009, 11:12 AM   #13 (permalink)
iovaykind's Avatar
If you were able to cover that up with something then it wouldn't look bad but it still doesn't help the problem with the dash light being turned on when there's no third brake light..
Old 12-09-2009, 11:17 AM   #14 (permalink)
sorry double post
Old 12-09-2009, 12:08 PM   #15 (permalink)
Make it complicated and find a way to send a signal back to the computer from where the 3rd brake light belongs!
