Originally Posted by leicester
The oil light flashes every few seconds but I checked the oil and it's fine. Any idea what it could be?
You sure it's the oil light and not the "check engine" light? A flashing "check engine" light indicates that the motor is misfiring bad enough to damage the catalytic converter.
If it is a flashing oil light, hopefully it's a flakey oil pressure sender or perhaps a bad wire from the sensor, otherwise it could indicate that the oil pump needs replacing. You can pick up a cheap oil pressure gauge from Harbor Freight (
http://www.harborfreight.com/cpi/cta...emnumber=92687 ) or probably something similar for twice as much money from an auto parts store, unscrew your oil pressure sender, and get a direct reading of your oil pressure.
Does anyone know any website where I could find the owner's manual to download? Doesn't necessarily have to be free.
Haven't seen one for the Gen3 rigs at camrystuff. You can hardcopies cheaply on ebay, or you can subscribe to a two-day pass at Toyota TIS ( techinfo.toyota.com ) for $15 and download any manual you want (although the Factory Service Manual has to be downloaded in itty bitty pieces)
