93 Carmy LE 2.2L No Start
I'm working on a 1993 Camry Le 2.2l 4cy for a family member. He said it suddenly died at a intersection and wouldn't start so it was towed home. I checked and it has fuel, spark, and air but still wont start? I thought it could be the timing belt broke but I have spark and the rotor turns with the cap off but when I turn the distributor all the way one way I can get the car to almost start that leads me to believe that the timing belt has jumped. Does this sound right?
Also I ohm checked the coil and the primary is .9 - 1.0 ohm and the secondary is 11,630 ohms I think the primary should be .3-.5 ? Would the coil cause what I'm seeing with the timing?
