Who's Electric Antennas are freezing up? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2009, 08:59 AM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation Who's Electric Antennas are freezing up?
I made the mistake of washing the car yesterday, just before the temps dropped into the teens all night, & now in the 20's for the day! Now my electric antenna only goes up 1/2 way!.....I guess I'll have to apply some WD-40 to it when it thaws out!......
ricamryman is offline   Reply With Quote
Old 12-11-2009, 09:11 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
You've got a working power antenna? My S2000 stubbie seems to be doing just fine
OTOH, I had a few ski trips last year where the power antenna on my Sequoia iced up to the point I had to wack it a couple of times to break off the ice so it would go back down.
Old 12-11-2009, 09:14 AM   #3 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
I live in Long Island and our temperature is dropping like crazy! We have the same situation and my power antenna gets on my nerves so much! It only goes up half way now and I'm really thinking about switching to the S2000 antenna if the mod required less work. Other than that, it probably won't hurt the motor and will just look ugly during the winter months.
iovaykind is offline   Reply With Quote
Old 12-11-2009, 09:51 AM   #4 (permalink)
What is the S2000 Antenna?
Old 12-11-2009, 09:55 AM   #5 (permalink)
iovaykind's Avatar
Its a mod many gen 3 camry owners do that switches it from OEM to a Honda s2000 antenna.. I believe its under the list of mods for gen 3 camrys. its stickied.
Old 12-11-2009, 09:58 AM   #6 (permalink)
View White95Cam's Photo Gallery
No liquid lube is required, it only attracts dirt. I do polish mine with fine steel wool to clean it and rub it with lock graphite. I still have the original mast after all these years.
W95c
White95Cam is offline   Reply With Quote
Old 12-11-2009, 10:03 AM   #7 (permalink)
iovaykind's Avatar
I have the original also.. I just stand it for winter and its still been working when springtime comes.
Old 12-11-2009, 10:09 AM   #8 (permalink)
hill8570's Avatar
See the DIY at http://www.toyotanation.com/forum/t65507.html for details.
Old 12-11-2009, 11:07 AM   #9 (permalink)
I have seen in other posts where owner installed and on/off switch for their antenna. They raised it and cut the power during very cold or winter weather.
W95c
Old 12-11-2009, 01:11 PM   #10 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Mine still works like new, but I have an aftermarket stereo, and the antenna stayed up all the time. I got tired of that, so I unpluged the antenna's power while it was fully retracted. Now it's just down all the time. I hardly ever use the radio function anyway.
If I ever get my car repainted, I'll shave the original antenna all together, and get a glass mount antenna. That way there will be no chrome tipped bump sticking out of the quarter panel. I've look into the s2k antenna mod, but...I'm not a fan it. IMHO, it looked out of place even on the s2k, and even more so on a gen3/3.5 Camry. Anyway that's just me. If you like, that's great! I just don't.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 12-11-2009, 01:16 PM   #11 (permalink)
iovaykind's Avatar
An On/Off switch is an awesome idea. Sometimes it doesn't even need to be up I'd think to get some local channels. Where can I find this mod and how would it be done? (Sorry to thread jack)
Old 12-11-2009, 01:20 PM   #12 (permalink)
I can't remember if it was on this forum or another one for Camrys, but the poster had mounted a toggle switch and spliced it into the power lead to the antenna motor.
W95c
Old 12-11-2009, 03:27 PM   #13 (permalink)
iovaykind's Avatar
Does the power lead to the antenna motor come from the stereo antenna wire? If it is, then I can see how its not hard to put a switch there. But if there's some sort of relay then it might be a bit more difficult.
Old 12-11-2009, 04:09 PM   #14 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
No its easy. Just needs 12v+ to the black/red wire from the radio harness. For fun you could splice the green illumination wire to the black/red. Make the antenna go up when you turn on the lights. All the relays and crap are back by the antenna so all its doing it waiting for the + input from the black/red wire to pop up the antenna. Remove that 12v+ and the antenna goes down. So any kind of switch to make and break that input makes things simple.
I went from the gray 12+ Acc wire to the switch to the black/red because my stereo has no power antenna output.
Thanks for the steel wool idea white95cam. Ill try that. The past 2 days driving to work in -17 degree weather has made mine only retract half way.
#2! is offline   Reply With Quote
Old 12-11-2009, 04:28 PM   #15 (permalink)
akhoundog's Avatar
View akhoundog's Photo Gallery
mine works now but does freeze sometimes. i spray it with disk brake cleaner. it's like viagra for my antenna
akhoundog is offline   Reply With Quote
