Big 3 wiring question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2009, 10:12 AM   #1 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
Okay yeah, I have used the search feature for question. Found a lot of threads and post but wasn't clear on one thing: what size fuse should I used to best suit for the alternator to battery (+). Should size of the fuse depend on how much the alternator is rated at or how much your audio amp is drawing from the current? IN my case, my stock V6 1mz alternator is rated 80a, do I need a 80a-100a fuse, or 120a-125a fuse cuz my amp is drawing that much from current?
ty**20 is offline   Reply With Quote
Old 12-11-2009, 10:13 AM   #2 (permalink)
oh yeah my amp is Infinity 1211a mono amp, 1300 rms @ 2ohm
Old 12-11-2009, 12:26 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
If you put anything higher than what the alternator is rated for you, you're essentially bypassing the entire point of having a fuse...
Chris Crash is offline   Reply With Quote
Old 12-11-2009, 01:51 PM   #4 (permalink)
so a 80a fuse is good?
Old 12-11-2009, 04:02 PM   #5 (permalink)
If you want to save your alternator, yes.
Or get a higher output alternator to give your amp more power.
Old 12-11-2009, 04:15 PM   #6 (permalink)
Thankyou Chris Crash. I will get a higher output alternator later when I have more $$..Now I need a 80a ANL fuse.
Old 12-11-2009, 04:19 PM   #7 (permalink)
View Kenny_McCormic's Photo Gallery
If your amp draws more than the alternator it will not work.
Kenny_McCormic is offline   Reply With Quote
Old 12-11-2009, 04:33 PM   #8 (permalink)
I'm not saying you NEED a new, beefier alternator.
I'm just saying I wouldn't try putting bigger fuses in it.
Because then you could fry your alternator.
Your current alternator will probably be able to power your amp just fine though!
Old 12-11-2009, 05:22 PM   #9 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
it will work till your battery dies
but that holding at max output, most normal usage you should be fine.
^ and leaving it that way!
