Transmission relation to P0136 code? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2009, 01:36 PM   #1 (permalink)
View tombs14's Photo Gallery
Hey guys,
I've been doing some reading on slipping transmissions. I had my 1995 (V6) Camry diagnosed, and received a P0136 code - which is the heated O2 Sensor Bank 1, sensor 2 (below the passengers seat).
My question is, can a faulty O2 sensor cause my transmission to slip and give trouble shifting?
Many vibrations while shifting from 1st to 2nd.
And once I put my car into Drive, the RPM is up to 3000 before my car even moves!
Anybody have any experience with any of these conditions. Your input would be greatly appreciated.
-Tom in IL.
tombs14 is offline   Reply With Quote
Old 12-11-2009, 02:04 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
A faulty O2 sensor (especially the downstream one you refer to) won't cause a slipping tranny.
I'm not much at diagnosing trannys -- yours sounds in pretty bad shape, but hopefully someone else with a bit more expertise will weigh in on that.
Old 12-11-2009, 02:14 PM   #3 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Originally Posted by tombs14 View Post
Hey guys,
-Tom in IL.
How long has it been since you've changed your transmission fluid?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-11-2009, 02:27 PM   #4 (permalink)
My father changed the transmission fluid in Oct, 2007 according to our books/records. At the time car had 143K miles on it.
I don't know if he has flushed since then without asking him, but today the milleage is at 165+K.
(Should there have been a change since then?)
Old 12-11-2009, 02:49 PM   #5 (permalink)
That mileage isn't too bad to go between a drain/fill. I'd recommend you drop the transmission pan, replace the strainer/filter, clean the pan and magnets, and pay attention to any large accumulation of metal particles in the pan sludge and on the magnets. Be sure to remember the position of the magnets in the pan, and re-place them that same way.
I am not saying this as a solution to your problem, but it may help. And paying attention to metal fragments may also give you an idea of the health of the transmission. Hopefully someone else can comment more about a specific cause.
How's your transmission oil level? I assume there hasn't been a leak somewhere and you're not driving on empty.
Old 12-11-2009, 03:29 PM   #6 (permalink)
View Kenny_McCormic's Photo Gallery
If you put the trans in manual low does it drive ok?
Kenny_McCormic is offline   Reply With Quote
Old 12-11-2009, 04:17 PM   #7 (permalink)
Earlier in the last year I would normally take off in 2nd or sometimes even L(ow) and wouldn't usually get vibrations/trembles.
Now in the last couple months, it doesn't matter. The transmission slips for all levels.
Also, I gave in and made plans to drop it off at a transmission shop Monday. Their mechanic says the O2 sensor won't affect transmission slippage.
Thanks to everyone for your information.
Old 12-11-2009, 04:52 PM   #8 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
That's probably your best bet
Chris Crash is offline   Reply With Quote
Old 12-12-2009, 11:21 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Sounds like your transmission may be on the way out. Putting it in L or 2 engages an additional brake band. So it'll hold gears better. But looks like that's not helping any more.
What fluid did he use? How's the condition and level of the ATF at this time?
You might want to try High Mileage ATF and change the strainer (plus wipe the pan and magnets). See if this helps. If you have a line pressure gauge, check the line pressure as well. It may also be on the low side, just suspecting.
Old 12-14-2009, 09:06 PM   #10 (permalink)
Well, I got back the diagnostic report. The O2 sensor had nothing to do with transmission malfunction.
Nothing "electronically" wrong, rather mechanically wrong. The guy stated that the automatic clutch was sticking every time it would change gears, or along the lines of that. Only a complete rebuild would fix, rather than a "simpler" solenoid problem (which is cheaper).
As of now, i'm searching for bids at online used tranmissions dealers. Of about 10 to 15, my best offer has been $600 (including shipping) with a 12 month warranty.
Thanks for the suggestions and info from everybody.
Old 12-14-2009, 09:45 PM   #11 (permalink)
Well, that low a price could mean you'll just get a junkyard pull and installed.
You might want to check your local Automatic Transmission Rebuilders Association members. I would.
http://www.atra.com/source/members/m...rch/search.cfm
Old 12-14-2009, 10:19 PM   #12 (permalink)
hill8570's Avatar
Any quotes for a rebuild? I'd personally rather have a rebuilt, known tranny than install an unknown used. Especially considering how much it'd cost to ship a tranny back for a warranty claim.
Old 12-14-2009, 11:00 PM   #13 (permalink)
Transmission repairman's quote was ~ 3K in a ritzier area of Peoria. Other known quote could land 1.5k+ for a complete rebuild.
Old 12-14-2009, 11:29 PM   #14 (permalink)
Marshall has one reman'ed for $1914 + $415 core (+$42 shipping to peoria). Rockauto prices. Carries a 3 year 100,000 miles warranty.
http://www.marshallengines.com/transmissions.htm
Or you can try Jasper Engines.
http://www.jasperengines.com/transmissions.php
This type of warranty (3/100K) is typical of a good "re-manufactured" transmission. Do check with them for installer requirements and available torque converter.
However, if you can pull it and do your own rebuild. A rebuild kit is about $200-250 or so, plus a reman torque converter $150 or so. See also:
Transmission Swap Write-Up and Photos
