Exhaust Question(s) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2009, 05:23 AM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Exhaust Question(s)
Ok, so the P0420 came back after I changed my O2 sensors. I was told this could mean two things, 1) exhaust leak, 2) bad rear catalytic converter.
It was recommended that I check all the flange connections for leaks before replacing the catalytic converter.
Here's my thought. I recently just put on a TRD muffler. The old nuts for the flange connection had to be sawed off. I am certain this will also be the case for the other flange connection(s). So "checking" them, unless a leak is absolutely obvious, will be a time consuming and extremely aggravating task. Because I'd have to saw off those nuts, get the bolt/stud out SOMEHOW, replace the gasket, and reattach it with new bolts/nuts. Sawing isn't even the big thing. Getting those old bolts off will be near to impossible. They'll be rusted to the flange.
Also, in a recent thread, I read that a flashing check engine light may mean that the engine is misfiring enough to damage the catalytic converter. A number of months ago I had to drive 100 miles with a misfiring cylinder.
Could this have damaged the catalytic converter? This P0420 code is very recent. I can't recall if it popped up before or after that incident. May have very well been after, in which case it may be related.
So what should I do? Replacing JUST the converter means taking it to a muffler shop/mechanic and get some welding done. A new catalytic converter with that front pipe is $800 from the dealer. And that's ONLINE, so shipping will be killer too. Might end up being the same total price as from a local dealer. The mid pipe is only $180 plus shipping, or more with no shipping from a local dealer.
Also, in another thread, I've read references to a TRD "exhaust." What is a TRD exhaust? Just a TRD muffler, or is an ENTIRE TRD exhaust system? In which case, what's so different about it (other than the muffler) from a stock exhaust?
Are aftermarket catalytic converters with the attached piping ok?
Some suggestions on what I should do are appreciated. Specific questions are bold.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-12-2009, 09:48 AM   #2 (permalink)
View Kenny_McCormic's Photo Gallery
You will see carbon where a leak is present.
Kenny_McCormic is offline   Reply With Quote
Old 12-12-2009, 10:02 AM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Are you sure you bought the right oxygen sensors for your vehicle? Cuz you could've gotten california emission sensors instead of fed spec sensors that might play a part in the code. That's what i've heard.
RU2CHKN is offline   Reply With Quote
Old 12-12-2009, 11:29 AM   #4 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
Go to a muffler shop and replace the converter. If you drove that far with a misfiring cylinder that converter is likely toast. Is there good back pressure? is the car hard to accelerate on the road or while in "Park"?
The TRD Exhaust is just a muffler that is bolted on. On of the 4Gen guys just put one on a few days ago, it's a recent post. That will do nothing to solve you problem though.
Is the exhaust overly loud? do you hear a leak? jack the car up or put it on ramps and look for a leak. There will be soot where a leak is present if you can not hear it.
Good luck.
PortugalFocus is offline   Reply With Quote
Old 12-12-2009, 11:44 AM   #5 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
taking part a rusted exhaust is fun. just saw and hammer out the rusted crap.
but, I doubt a little leak will cause a code to pop up, you would hear the exhaust leak.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 12-12-2009, 12:57 PM   #6 (permalink)
Yeah, I put a TRD muffler on. I was just wondering if if there was more to that exhaust system, or just the muffler. But I get it.
My purpose asking about the TRD exhaust, in case there was more to it, is that if I'm going to spend a long time working on those flanges, I feel like I should be replacing something, rather than putting an old rusty part back on. The midpipe is fine, rust-wise. No holes or anything. I guess I'd be ok not to replace that.
Alright, so let's say I get a new catalytic converter, but I don't want any welding involved. I'd rather buy one already with the front pipe.
I don't think I'll go with RockAuto because of shipping. But the RockAuto brands are Bosal and Walker. I've never heard of these names. Anything to stay away from?
Old 12-12-2009, 01:06 PM   #7 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Don't need to weld or have the front pipe!
Just slide one over the other and clamp it.
That worked for me when I replaced my resonator with a cherry bomb (poor choice)
Chris Crash is offline   Reply With Quote
Old 12-12-2009, 02:55 PM   #8 (permalink)
View bmxr4life87's Photo Gallery
What part of oklahoma do you live in? If your close enough to tulsa I could offer a helping hand
bmxr4life87 is offline   Reply With Quote
Old 12-12-2009, 10:48 PM   #9 (permalink)
Tulsa. Woodland Hills area. PM'd.
Old 03-12-2010, 11:29 AM   #10 (permalink)
View 91Cress's Photo Gallery
Not sure if this should be same thread. Doing Census work I separated the exhaust at the two flanges. i looked under last night, can move it, the separation is front of the two flanges. There is a small section of pipe that is about 2 inches or so long to the AFT of whatever that is--muffler, cat converter?--with a bit of a lip on it. The AFT part of the exhaust w/the two flanges is just hanging there, well attached on to the rest and on out the rear.
I can't see too well as it is not jacked up.
Can I reattach the pipe somehow to the flanges? I made an appt to repair it before I looked at it for an auto shop 24 miles away (the nearest muffler shop is 2.5 hr drive) but want to know before I go what the problem is and how to fix it.
I was trying to tell from the threads here, but my problem is different. Didn't have any problem w/leakage before.
91Cress is offline   Reply With Quote
Old 03-12-2010, 11:16 PM   #11 (permalink)
Is the question about whether you can re-attach a pipe to a flange? I didn't understand part of this post.
I imagine it would require some welding.
