Automatic Overdrive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2009, 03:49 PM   #1 (permalink)
View BonesTheRipper's Photo Gallery
Arrow Automatic Overdrive
Hello Fellas,
i have a 93 camry LE... automatic. It has a bad habit of not engaging overdrive until you've been on the road for a while. only on cold starts like early in the morning on the way to work. i think the overdrive doesnt engage until about 4 miles into my commute. i noticed that when i warm it up before i leave, the overdrive kicks in sooner. this is the 2nd trans this camry has had... any thoughts, tips, tricks?
thanks,
bones
BonesTheRipper is offline   Reply With Quote
Old 12-14-2009, 04:07 PM   #2 (permalink)
View Kenny_McCormic's Photo Gallery
Mine does this too, I think its just because the trans is cold.
Kenny_McCormic is offline   Reply With Quote
Old 12-14-2009, 04:09 PM   #3 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
This is normal operation. The ECU is programmed not to engage OD until the engine/trans reach a specified temperature to reduce unneeded wear and tear on the transmission.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-14-2009, 07:34 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
for what its worth....x3
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-14-2009, 08:23 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Can always do a check of the engine coolant temperature sensor and make sure it's still measuring the correct resistance for the temperature.
