In need of clearing my corner lamps? 98' LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2009, 05:04 PM   #1 (permalink)
Natural White Ninety8
ry186an's Avatar
View ry186an's Photo Gallery
I have found some on eBay for around thirty dollars.. But is there a way to just remove the yellow reflector? Thanks for any and all input!
By the way; Im new to the forums, just signed up today!
My name is Ryan, and I have a 98 Camry LE 5S-FE
Cant wait to meet some people and become a name on here hopefully
Temporarily Stock 1998 Toyota Camry LE (5sfe)
ry186an is offline   Reply With Quote
Old 12-15-2009, 05:12 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Welcome to TN!
The way to remove the orange reflector is to place the lamps in your oven set at 300 degrees F for about 5 minutes, then pry the clear cover off. The orange reflector should just pop out.
Then reglue the clear cover.
Chris Crash is offline   Reply With Quote
Old 12-15-2009, 07:20 PM   #3 (permalink)
View skuttduck's Photo Gallery
Originally Posted by Chris Crash View Post
Welcome to TN!
Good luck with that. I tried to get apart my clear corners on my 2000 camry and I was unsuccessful.
I wound up leaving it longer and longer in the oven, and it wouldn't budge.
$30 will save you the headache!
skuttduck is offline   Reply With Quote
Old 12-15-2009, 07:32 PM   #4 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
It's not like headlights with a rubbery sealant to melt and separate. It's chemically glued together so opening them up isn't as easy as putting it in the oven.
I did it for my 2000 Camry with aftermarket corners. I trashed 1 set experimenting and my second set didn't quite come at as I hoped. I found the best way to do it is to use a heat gun to slowly heat the joint and cut it with a small sharp blade. I tried the oven and it actually ended up deforming the housing and hazing the chrome inside.
I made a thread with my results: Gen4.5 Custom black and clear corner lights trial runs
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 12-15-2009, 08:04 PM   #5 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
just depends how you do it. i took mine out to black out the reflecters and it came out just fine =] just do the oven on 250 for 5 min and watch it every second. one of my housings started getting really flimsy and soft so i took it out and nothing happened but i get the housing off just fine =]
Spitfire is offline   Reply With Quote
