MADDENING Idle problem,,please help
o.k. been here before, quick overveiw,,1996 2.2 camry runs great all around town,in constant distance driving the car while moving it develops a miss, then will not idle at a stop, turn the key off, then on, the problem disappears for a while then returns, if the car sits for awhile to cool down, you will get another 10-sometimes 50 miles from it till it coughs again,,,sometimes driving the car clears itself,but will come back soon,,next morning its fine again,,one day I got 75 miles, the next I got 10,,,
I've replaced the coolant temp sender, coil,wires,cap, fuel filter, fuel pump, car has been to toyota dealer, replace iac controller,checked for broken or leaky hoses, nothing has worked, car shows no codes and can reset itself as fast as a stall at a light, hit the key and its fine again,,,does anybody have a new idea,,,the only thing I can add to the diagnosis, is without the backseat in, both pumps old and new do not prime when the key is turned on, they only energize when the car runs,, even at a stall with the key still on you cannot hear the pump, is this a toyota thing or should I hear the pump prime when the key is hit after an overnight sitting
