remote starter question on camry 99 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2009, 01:50 PM   #1 (permalink)
View smilecow's Photo Gallery
I am going to install a remote starter on camry 99 2.2l
I have a problem. According to the wire info, the accessory wire's location is "test as ignition." The colors of the accessory wire and
ignition2 wire are the same.
Can I just use the ignition2 wire as the accessory wire? Do I have to use a relay?
thank you so much for your reply\
problem is solved!!!!!!!
smilecow is offline   Reply With Quote
