First of all, winter sucks... It's not so bad if the roads are still dry, but still sucks...
I made a few major changes with the car; aside from the supercharger + turbo, I have recently swapped to a lower stall speed torque converter. The stall is now at 3000RPM, hoping to get more response and better control of the instant power delivery the Camry now offers. I am on winter tires though, and for video's sake, I purposely let the tires break loose
With the built auto, it is very harsh on the transmission to upshift during wheelspin, so you can see how I lifted the throttle between shifts to take it easy on the trans.
I tuned it up to low boost so far and go easy since it's winter anyway... The numbers are promising though, with 520 WHP & 480 lbft of torque at 22 PSI. This has already shown a 20 WHP increase before twincharging at the same PSI. My old best was 567 WHP @ 26 PSI, and I know that once I turn up the boost, it will crack over 600 WHP
For safety reasons, I didn't do my usual "wrap the speedo" videos...LOL Braking is severely compromised on winter tires and cold pavement (and blotches of slush/snow too). It's still a good video though and hope you guys would enjoy.
For reference, the turbo I am running (HKS T51R, or a 71mm turbo and 1.00A/R) would never reach full boost until 5000+ RPM, and is indeed a very laggy on a 3.0L V6. Due to twincharging, the turbo now spools almost instantly, and now reaching FULL boost at 4000RPM
Don't forget to watch the whole dyno video or you'll miss the 3ft of flames out of the exhaust!
Here's a brief list of the setup:
'94 Camry V6 LE
1MZ-FE 3.0L V6
Wiseco 8.0:1 CR Pistons
Pauter Forged Connecting Rods
3MZ-FE crank, balanced and radiused
CCHT Ported Cylinder Heads
Engine Built By CCHT
Fully Balanced with Flex plate, crank pulley, etc..
CatCams Valve Springs
SI 1mm Oversized Valves
TOGA Oil Pump
ARP Main Studs
ARP Head Studs
2001-up OEM Toyota 1MZ MLS Headgasket
FAL Oil Sandwich Adapter (Oil feeds)
Custom Sidewinder V-band Turbo manifolds
4" Downpipe
3.5" Midpipe
3" Full Aluminum Exhaust
XForce VAREX Electronic Muffler
HKS T51R KAI BB Turbo (71mm); 1.00 A/R
TRD Supercharger, gives 6 PSI (5.5PSI pulley though)
68mm Overbored Throttlebody
Precision 750HP FMIC; 31.5" x 10.5" x 3.5"
Synapse Synchronic BOV
Tial 44mm Wastegate
Shore 80A Filled Front Engine and Transmission Mount
Solid Transmission Torque Rod Mount
Custom Urethane Dogbone Mount
Import Performance Trans (IPT) Built Automatic Transmission
3000RPM Stall Converter
Custom Manual-Matic Shift Control (Manual gear control)
Dual B&M Hi-Tek Transmission Coolers
Delphi 720cc/min Injectors
Custom CNC -6AN Fuel Rails; dual feed
Dual Trickflow inline Fuel Filters
Dual Walbro 255 LPH Fuel Pumps
Painless Fuel Pump Relay Kit
Turbosmart Fuel Pressure Regulator
'03 Toyota Highlander Alternator
DMT Meth Injection (M5 Jet)
Turbosmart E-Boost2 EBC
APEXi Turbo Timer
PLX DM200 Organic Display Gauges
Dual Wideband O2's
PLX Oil Pressure
PLX Transmission Temp
PLX Water Temp
AEM 1060 EMS Standalone
AEM IAT and Coolant Temp Sensors
AEM 5-Bar MAP
Motec Hall Effect Crank Sensor with Trigger Wheel
Milled OEM Toyota Cam Sensor
Haltech Ignition Modules
Factory ECU/ Standalone layout; controls transmission and stock functions
HKS Twinpower DLI
MSD Voltage Ignition Booster
Chrysler 300M Coilpacks
Denso IK34 Plugs, gapped 0.022"
Battery Relocated to Trunk
Hella Battery Kill Switch
KSport RoadRace RR Coilovers; 15 kg Front & 13 Kg Rear
Whiteline RSB
2-piece Supra Front Rotors
LS400 Dual Piston Front Calipers
Porterfield R4S Pads
235-45-17 Pirelli 240 Sottozero
Volk SE37k 17 x 7.5" +40mm Wheels
+ a few I may have missed...
