96 camry 115k spun bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2009, 12:19 PM   #1 (permalink)
View brk2586's Photo Gallery
USA 96 camry 115k spun bearing
I've got a 96 Camry with the 5sfe 2.2, and keep up ridiculously with maintenance and routine fluid changes ESPECIALLY OIL. I'm Driving at 65 mph down the highway at a normal RPM and all at the same time I hear an intense knocking and the oil pressure light comes on for all of one second, and then disappears. The oil pressure light is now off, and I am now left with the sickest knock you've ever heard. Checked the oil levels and it is full. The knock is definitely from the lower end of the motor, and My conclusion is that it is roasted. I've already accepted the fact that I need to swap it out, but my question is simply WHAT THE **** ?!?!? I've read time and time again 5sfe's running strong for over 200k, and mine pukes at 115k? any suggestions / comments as to why so instantly, randomly do I lose a bearing like that?
~BK~
brk2586 is offline   Reply With Quote
Old 12-19-2009, 12:42 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
how often did you change the oil?
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 12-19-2009, 01:11 PM   #3 (permalink)
View Kenny_McCormic's Photo Gallery
Drop the pan and have a look, maybe you can save it. I too want to know what oil and filters you used and your oil change interval.
Kenny_McCormic is offline   Reply With Quote
Old 12-19-2009, 02:29 PM   #4 (permalink)
No way to save it. After the knock I made it 5 miles home after spinning the bearing... with the oil pressure light coming on and off intermittently, which leads me to believe the oil pump went. anyway with that 5 miles the knock went from oh **** what's that to **** it I'll make it home...and barely did. the motor is toast. Changed oil every 3500 mi. with exxon conventional oil and a standard fram filter religiously. I stuck with conventional because the inside of the head looked...very dirty from inside the cap view....and didnt want to disturb any of the "gunk" that might have been holding an inner seal together. Now, It wasn't insanely dirty, but not as clean as I would've liked. it is a "dirty cap" car.
Old 12-19-2009, 02:31 PM   #5 (permalink)
I'm just not happy. Car ran like a champ
Old 12-19-2009, 03:46 PM   #6 (permalink)
The Fram filters probably didn't help.
Old 12-19-2009, 05:51 PM   #7 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
How long have you owned the car?
If you got it recently used, well shit happens. Good luck with the swap though. 5sfe engines arent hard to find if your current one isnt rebuildable.
carsrus is offline   Reply With Quote
Old 12-19-2009, 05:54 PM   #8 (permalink)
View stephenson's Photo Gallery
Why would a Fram filter, or any other generally reasonable filtering device cause a spun bearing?
Stuart Stephenson
1999 Camry LE L4
1988 Jeep Cherokee L6
stephenson is offline   Reply With Quote
Old 12-19-2009, 06:24 PM   #9 (permalink)
werkit217's Avatar
View werkit217's Photo Gallery
depending on how mechanically savy you are, you would have to drop the oil pan and remove the rod bearings and inspect the bearings and crank shaft, I think the crank bearings should be just fine... ps fram oil filters have never hurt anybody
I build cars the way I build them, anybody who thinks any different, well... they're just wrong
werkit217 is offline   Reply With Quote
Old 12-19-2009, 06:41 PM   #10 (permalink)
Fram filters are notorious for being of poor quality. There have been instances of them falling apart basically and clogging up oil passages.
That is not to say that's likely. Ive used them before without any issue, but there are better quality filters for the same price if not cheaper. AC Delco filters are one example.
I doubt the filter caused him to spin a bearing, nor does anyone with a fram filter need torun out and change there filter asap. Theyve just gained rep of being cheap, but quick lube places use filters that are ALOT worse, as in they cost 75 cents each.
Old 12-19-2009, 06:41 PM   #11 (permalink)
Bdub215's Avatar
Exxon oil? i cant vouch for them but in a engine that is prone to sludge i'd at least go for a better known oil and have it at least be synthetic blend or a full synthetic. you get that at a gas station or something ?
Old 12-19-2009, 07:51 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Post 1996 ones are known as sludge makers. It's after 96 that Toyota cranked up the heat to meet stricter emissions requirements. So if you have sludge or varnish in a 96, the engine may not have been maintained well before you got it.
Exxon (= Esso = Mobil) should be fine. Don't see problems with it because Toyota sells re-branded Mobil dino oil. I had problems with Fram's anti-drainback valve not working and noisy start ups. So I used a Fram filter ONCE. That's it. Now it's Purolator PureOne, Motorcraft, Bosch Filtech, Mobil-1 (made by Champion Labs).
I think oil starvation contributed to the sudden failure. The oil light may be a result of the excessive bearing clearance so it probably just showed the result of the failure.
Take off the valve cover and take a picture for us.
Old 12-19-2009, 10:55 PM   #13 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-19-2009, 11:30 PM   #14 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Don't pay any attention to the bullshit RE Exxon oil / Fram filters. At 3500 mile intervals, a good dino oil (which Exxon is) and a reasonably OK filter (which Fram is) should have been more than adequate.
Shit happens. From the symptoms, it almost sounds like your oil pump pickup got a load of crap in it (rather common in a heavily sludged engine, but shouldn't have happened if your rig was maintained as you say from the get-go), and one or more critical bearings got oil starved. Be interesting to see the results of a teardown.
Old 12-20-2009, 12:15 AM   #15 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
I beg to differ. I have only been using Fram filters for my 95 Camry (at 165k now) and I never had a problem with them.
bdy0003 is online now   Reply With Quote
