No, you have to manually drain the differential. Or get the shop to do it. Otherwise it won't get exchanged out by the machine.
Get them to do this to see for yourself: flush and put new fluid in the transmission, and look at the color of the ATF drained out from the differential when they do it
afterwards. Do you think that's new fluid?
Gen 4 should be able to filled both the transmission and the differential from the SAME DIPSTICK TUBE. You just have two different drains. (Just who thought of that?)
Originally Posted by ghost111
I have a 99 Camry V6 with the auto trans.
I have searched the forum for a definative answer and really have not found one.
Does this car have a seperate drain and fill process for the differential. The reason I ask is, I have found a lube shop that uses the new T-1 machine to do a total clean an the auto tranny [not Jiffy Lube] and I don't know if I need them to treat the diff. as a seperate drain and fill.
Please explain.
