How to fix hood prop rod clip - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2009, 08:14 PM   #1 (permalink)
TN User
View baber's Photo Gallery
Hello Guys,
I have a 98 Camry V6 XLE. The hood prop rod holder clip (the plastic U shaped clip that holds the hood rod in place) is broken.
Where can i get a replacement and how to install it once i get it.
Thank You
baber is offline   Reply With Quote
Old 12-20-2009, 08:34 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Originally Posted by baber View Post
Hello Guys,
Thank You
Git it from the dealership. It just pops in/out.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 12-20-2009, 09:05 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
You mean the grommet that holds the rod onto the front of the car? P/N 53454-33010, about $5 from finer stealerships everywhere. Or the clip that the rod snaps into when not in use? P/N 53455--33011, about $3 from the same.
Old 12-21-2009, 09:56 AM   #4 (permalink)
Gameroom cash: $303255
Use a needle-nose pliers to grab and pull the remaining pieces of plastic out. If you scratch the paint under it, use a bit of touch-up paint before reinstalling the new prop rod holder. The new holder just pushes in. I had to do this several times on my 98. The part doesn't do well in the cold weather. I found putting a dab of grease in the holder helps a bit to keep it from breaking again in the future.
Mike
Mike Gerber is online now   Reply With Quote
Old 12-21-2009, 09:59 AM   #5 (permalink)
TN User
4th Generation
Yes thats what happened to me Mike. I am unable to pull out the remaining plastic which is not flat....I was confused if it was the right way to do...so I thought better ask before doing. But I am relieved since you say u faced the same problems.
I could not find the part anywhere else. I'll check with the toyota dealership today.
Thank you all for your replies !!!
