Broken belt ... How to time 2.2 engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2009, 12:43 PM   #1 (permalink)
View ducman73262's Photo Gallery
Well waited little to long and it happen yesterday " thanks god only few blocks from home" I new should done it when had it up last week doing the struts ....Im at point of pulling the harmonic balancer off and did few searches but cant find any info on how to retime this engine 1997 2.2 any help to a link would be great ....
Thanks
ducman73262 is offline   Reply With Quote
Old 12-21-2009, 03:35 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
DIY: Timing Belt + Water Pump + Oil Seal Change - 5S-FE
Part 1 - http://www.toyotanation.com/forum/sh...d.php?t=264425
Part 2 - http://www.toyotanation.com/forum/sh...d.php?t=264429
Its a breeze to set timing. Rotate cam untill it pops into the V groove, NOT the dot. Put belt on, lower cover and rotate crank to TDC. Put belt on cam and tension it. Start the car, make sure the belt has good tension. Mine had slack on the underside so i loosened the tensioner and got it all the way up and the belt should be tight all the way around then. The guy in the DIY had slack on the top part so im just throwing in the little hiccup i ran into.
carsrus is offline   Reply With Quote
Old 12-21-2009, 10:40 PM   #3 (permalink)
Easy enough thanks ... one question shouldnt the crank be tdc in the compression stroke ? Other than throwing a compression gauge on cylinder one is there any other way of knowing this since you cant get finger over the hole to feel for the pressure ?
Old 12-21-2009, 10:46 PM   #4 (permalink)
View Brand's Photo Gallery
I am just curious how many miles do you have on your car?
Brand is offline   Reply With Quote
Old 12-21-2009, 11:12 PM   #5 (permalink)
just flipped 115,000 .... should of listened and changed it at 90,000 not waited , the day before we drove 60 miles up north and didnt return home till 1:00 am so Im very lucky didnt get stranded in the cold on the highway .
Old 12-22-2009, 09:04 AM   #6 (permalink)
Yeah you could put a compression gauge on it. I didnt bother with that and just roated the crank to 0 degrees and set the cam and you should be on the money. The idea is that there is no compression stroke on the actual piston, it just goes up and down, so if you set it at TDC on the cam and set the piston at 0, you have timing set.
Old 12-22-2009, 09:28 AM   #7 (permalink)
Great thanks again .... some reason I looked at it little deeper for sake of not going in twice .
Old 12-22-2009, 12:11 PM   #8 (permalink)
View djb2's Photo Gallery
It's good to have objective reports on the actual lifetime.
Was it covered in oil, or was there anything else that would have shortened its life?
115K miles is more than the recommended change interval, but a little soon to break.
djb2 is offline   Reply With Quote
