So I finally found some time and decided to tackle the leaks my girlfriend's 93 Camry has...
I didn't realize it was this bad..I went to look for where it was leaking to find EVERYTHING on the underside of the motor area was coated in oil and grime. Did a quick cleaning with some simple green and brake cleaner.... ran out of both so I didn't get it as clean as I wanted.
Ended up finding a BAD leak from the oil pan gasket. Pretty much within 3 minutes of idling I saw it dripping. The valve covers looked to be leaking too from the oil and grime I saw before cleaning.
So I'm sourcing some parts and am going to dive right in and replace the valve cover gaskets and reseal the oil pan and throw a gasket on there. Looking around I've found a valve cover gasket set with spark plug gaskets for $50 and an oil pan gasket for $14... her motor also moved a good 4" when she put it in drive and I saw that her torque rod bushing was gone, so I found a generic one for $33.
So my question is this:
While taking off the intake plenum to access the rear valve cover, should I replace anything else since I've gone through the trouble of pulling all that crap off? I just want to know since this is going to be a one day job..my girl needs her car back by the end of the day, so I can't afford to have to wait on parts. Maybe some random coolant hose that is a PITA to get to and prone to breaking? Anything like that...
Also I think she told me the Penzoil (She gets her oil changed there....
) guys said that she has an oil leak AND a transmission leak....I really couldn't tell where the transmission leak was if there even was one, since there was so much grime and crap under the car. Anyways I don't have the tools or time to pull her damn automatic transmission out and fix a leak if it has one, so I plan on just dumping a bottle of stop leak in there. Bad idea?
Lastly, what is prone to breaking on these cars? Her climate control panel already broke and air only comes out of the defroster vents..I think those are related, the outside driver door handle broke, her horn doesn't work, and the air bag light is on. Seems everything is breaking on the inside... but that's not too bad. I want to know if anything mechanical is prone to failure that I can take countermeasures against. The car's had its oil changed every 5k miles and the timing belt was done about 15k ago, the intake filter was just replaced, etc... so the car's been taken care of fairly well mechanically.
I just want to make sure the car lasts another 100K or so (she's at 159K now), so she can finish college and get a job to pay off her student loans without adding a new car loan to that list.
I appreciate any comments/criticism that I get from you guys. I don't own a Toyota, but I've seen how much abuse they can take and how long they last.
