cold+automatic trans=wont shift up? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2009, 03:11 AM   #1 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
when it is 40 or below and i don't let the car warm up for at least 4 min the trans wont shift up or down it stays in the same gear regardless if i floor it or let off the gas until it warms up usually 2 miles down the road it will shift up but until its at running temp it wont downshift
i changed the trans fluid and filter think that was the problem even added lucasoil trans additive
so im thinking its some trans sensor/throttle sensor OR a cold start injector the hissing noise on start up but i don't thing this gen 5sfe has a cold start injector?
thanks mike
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 12-24-2009, 08:17 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
its completely normal, all 3 of my camrys have done it. 1. it warms up the tranny fluid and the tranny before normal operation, to prevent ware. 2. it warms up the engine faster, also to prevent ware. you dont need to change anything or do anything. just let it warm up the way its designed, or let he car sit for that 4 mins. i usually do the latter and plan that into every trip.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-24-2009, 10:54 AM   #3 (permalink)
really? wow that is quite thoughtful of toyota so then what causes it to do this the computer?
also i use to clean the cold start injector about every 6 months that was on my 91 celica i cant find any such thing on this gen 5sfe is there one?
Old 12-24-2009, 10:54 AM   #4 (permalink)
View Kenny_McCormic's Photo Gallery
Weird, mine just wont go into 4th until its been running for a few minutes. Otherwise it acts normally cold, even at 0 degrees.
What color was the fluid? How did you "Change" the fluid?
Kenny_McCormic is offline   Reply With Quote
Old 12-24-2009, 12:44 PM   #5 (permalink)
Gameroom cash: $303255
"also i use to clean the cold start injector about every 6 months that was on my 91 celica i cant find any such thing on this gen 5sfe is there one?"
No there isn't. The fuel mixture to start a cold engine is completely controled by the computer and the sensors that feed the computer information.
"Weird, mine just wont go into 4th until its been running for a few minutes. Otherwise it acts normally cold, even at 0 degrees."
That's normal behavior. If the OP has a problem with it not shifting out of first gear when cold, then that is a real problem.
Mike
Mike Gerber is online now   Reply With Quote
Old 12-24-2009, 12:44 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
it does vary from car to car a little, often times any difference is with the temp sensors and how well teh cooling setup is working. i have a CAI and even that makes a difference compared to an SRI.
my recommendation for the v6 guys is to just get one of thoes supercharger things and that will help warm the engine up a little faster, thats why i got one.
R.I.P.
Car Domain:
Old 12-24-2009, 08:13 PM   #7 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
^ i hate you. lol s/c cheater ha ha. jk jk
loves it when i make ppl regret not downshifting ;-)
TRUST YOUR DRIVER RESPECT YOUR MONKEY
http://www.cardomain.com/id/slpr1mz
slpr1mz is offline   Reply With Quote
Old 12-26-2009, 08:43 AM   #8 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
Toyota is not the only manufacturer to do this. The computer does use the temp sensor to determine when the auto tranny should shift up. Think of it this way, when you get up in the morning, are you as energetic as you would be a few minutes later? That's similiar to the way the auto tranny works when cold
zythr is online now   Reply With Quote
Old 12-27-2009, 03:56 PM   #9 (permalink)
Carzzz's Avatar
View Carzzz's Photo Gallery
+1
Carzzz is offline   Reply With Quote
