running lean with O2 sensor problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2009, 07:33 PM   #1 (permalink)
View machinehead93's Photo Gallery
4th Generation running lean with O2 sensor problem
Hi,
i have a 97 camry V6 with 124k, check engine light came on the other day with a list of codes
P0130
p0133
P0135
p0150
p0153
p0155
p0171
So I went and replace both upstream o2 with denso sensor. I also replace the fuel filter and check for vacuum leak and didn't find anything leaking. But after a couple miles the CEL came back on with the same code. What could be the problem? Has anyone experienced the this problem before?
Thanks in advance
machinehead93 is offline   Reply With Quote
Old 12-24-2009, 08:59 PM   #2 (permalink)
View Novice_cardude's Photo Gallery
Did all the codes come back? or just one or two? And you'll probably want to take into account lazy people such as myself who don't want to look up what each code means, and just include a description of the code in the post. thanks!
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 12-25-2009, 03:11 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Since you've already replaced the sensors, then check EFI fuse #2 (heater circuit) to make sure it's not blown. Other wise the ECM
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-25-2009, 05:27 PM   #4 (permalink)
would a bad maf sensor cause it to run lean? and where is the EFI fuse on the car? thanks
