New Front Struts and funky noise
So i just installed some new Tokico blues up front. Everything looked good, except for the lower coil spring absorbers - as in circular flab of rubber that goes between the coil spring and the strut base. On one of them had a 2 inch hole, and the other had a 1" tear in it. As ghetto as it is, i glued both back - sourcing a replacement locally right now is basically impossible. I was stuck and had to reassemble it b/c the car was needed.
I'm getting this metal on metal sounding clinking type noise from both sides of the front. It's pretty faint and only happens on contact with bumps in the road. Is this the kinda noise i get from dead rubber absorbers?
As far as i can see, the spring is basically stationary because it's under tension between the upper mount and strut base. Even when hitting bumps the spring shouldn't move or wiggle, right??? Based on this, why would the lower rubber absorber thing be even necessary?
Thanks!
