Originally Posted by toyomoho
If the dipstick states to check the diff fluid via the refill plug then use that method. The fluid should be level with the filler hole opening. Sometimes it is a little higher and some start to drain out but this is OK, just put the plug back in.
If you are going to drain and refill the diff make sure you can loosen both plugs, filler and drain before draining the diff fluid. More then one person after draining the diff has found out the filler plug is frozen in place.
Fill the trans to the cold fluid line on the dipstick. Then recheck when fluid is hot. Move the gear selector from Park to Low and back, check fluid with engine running and trans in Park.
Some V6 trans did not have a separate diff filler. On these trans there is a drain plug on the diff housing but no fill plug, just a boss where it would have been machined into the trans.
i don't knwo if i did it correctly
i noticed my 94 V6 1MZ-FE transmission has atf drain plug, differential drain plug, filler tube for ATF, and filler plug for differential.
i jacked up the car and removed the differential drain plug, atf came out,
then i also removed the atf drain plug, more ATF come out, roughly about 3.7 qt to 4 qt total.
then i put the ATF drain-plug back, leaving the differential drain plug open, and start refilling ATF through ATF refiller tube, to my suprise, after refill about 2 qt of ATF, the new ATF starts pouring out from the differential plug. this further confirm my V6 transmission ATF and differential indeed shares fluid.
normally, with the vehicle level on ground, topping off filler differential plug until it overflow is the correct level for differential, i know the dipstick said check differential through filler plug but it is kinda confuse if i should use dipstick or filler plug for differential.
but anyway, i did not even bother to undo the differential filler bolt and mess with pumping atf in there, i just refill about 3.5 qt of ATF through atf filler tube, and went for test drive, every gear seems shifting ok.
the factory service manual never mention 94 v6 transmission share ATF and differential.
and it even said the differential uses 0.9 qt while the atf uses 3.7 qt on drain/refill.
