tried retreiving codes on 95 le... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2009, 04:02 PM   #1 (permalink)
View sc2dave's Photo Gallery
i hooked up the jumper wire,turned the key to on,and the check engine light did not stop blinking at all.No pauses,no shorter blinks,just continuous blinking.Hmm, let me guess new ecm time?
sc2dave is offline   Reply With Quote
Old 12-25-2009, 04:51 PM   #2 (permalink)
Gameroom cash: $303255
If this is the 4 cylinder 5SFE engine (OBD1) it means you don't have any codes present. Your ECM is fine. The V6 engines for 1995 were already OBD2 and you would need an OBD2 code reader to pull codes for that engine.
Mike
Mike Gerber is online now   Reply With Quote
Old 12-25-2009, 06:58 PM   #3 (permalink)
weird thing is that I've been driving with BOTH O2 sensors disconnected for about 2 days now and i don't get a c.e.l. at all,as if nothing is wrong. Yes,it's the 5sfe
Old 12-25-2009, 09:17 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
FWIW, I had the same thing happen with my 95 5S-FE -- I never could get a CEL when running with one or both oxygen sensors disconnected, even when using the prescribed driving pattern in the FSM. Let me know if you figure out what's going on with that...
Old 12-31-2009, 07:55 PM   #5 (permalink)
View yotatoter's Photo Gallery
from what i know the continuous blinking means ,,no codes present
yotatoter is offline   Reply With Quote
Old 01-01-2010, 02:49 PM   #6 (permalink)
View Never95's Photo Gallery
95 Camry as well, I have had both o2 sensors disconnected with no CEL. If you want to check try disconnecting the ECT, it gave me a code within 2 minutes.
Never95 is offline   Reply With Quote
